Help. Can the anti theft blinking light drain my battery?
Discussion in 'Technical Chat' started by Thisisformydad, Jun 10, 2019.
  1. Jun 10, 2019 at 7:39 PM
    Thisisformydad
    Thisisformydad [OP] New Member
    2014 Burgundy Tacoma TRD Sport
    I’ve learned the blinking light of a car with a key in it is the anti theft. My battery was drained while I was on a long vacation and I’m wondering if the blinking light could have done it. Any info is helpful thanks
  2. Jun 10, 2019 at 7:40 PM
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
    What’s a long vacation?
  3. Jun 10, 2019 at 7:42 PM
    Nunya Bizness
    Doubtful, that security system doesn't draw much power. If your battery was dead it was likely just due to it sitting a while.
    How long were you away?
  4. Jun 10, 2019 at 10:42 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Maybe if it was a turn signal blinking for a week but not a low power led. High power leds can consume whole amps while low power leds consume milliamps.
  5. Jun 11, 2019 at 12:59 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It comes back to how long you are away .
    There are a few draws always when the battery is connected
  6. Jun 11, 2019 at 1:25 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Welcome to the forum. To answer your question, NO, it's highly unlikely that the anti theft will kill your battery.
  7. Jun 11, 2019 at 6:32 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    While I would tend to agree with people who think that the blinking security light will not drain a battery, it is not helping your battery to stay alive. The current draw is small, but a draw, nonetheless.
    If a real drain is suspected, I find the best way to locate it is to use the amp scale on a voltage ohm meter across all points in all of the fuse boxes. Fuses are removed one at a time, amp meter probes inserted. I usually wait about 1/2 an hr. to start the test. Gives the more active circuits some time to go to sleep. Those higher consumers may wake up when you hit them with the probes. A quick glance at the fuse diagram will identify that fuse - usually security related.
