Help! Broken throttle body bolt!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoMal, Jul 5, 2011.
  1. Jul 5, 2011 at 5:28 PM
    TacoMal
    TacoMal [OP] Well-Known Member
    California
    09 TRD Off Road Dbl cab
    Wet Okole's, Relentless Sliders, Plasti Dipped badges and wheels
    I was putting the throttle body back together and torquing the bolts (9ft lbs) and one of the ones on the top broke leaving about 1/2 of the thread still attached. What am I going to do?? Obviously I need a new bolt. If I tighten the rest and put everything back together, will I be able to get to the dealership to get a new screw okay?
    How am I going to fix this?!
  2. Jul 5, 2011 at 5:50 PM
    TacoMal
    California
    Ok, I got the bolt completely out but the dealer is saying it could take up to a week to get the bolt in. Will I be able to drive with the other three bolts snug?
  3. Jul 5, 2011 at 5:53 PM
    snowmansgarage
    snowmansgarage Well-Known Member
    Portland, OR
    '06 TRD Offroad AC Tacoma
    You should be fine until the new bolt arrives. Have you asked the parts department if they can expedite the order. I know with the company I work for it is possible but it's a few extra bucks to get the part next day.
  4. Jul 5, 2011 at 5:55 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Fire up the engine and rev it a few times. If idle RPM isn't excessive and the check engine light doesn't come on, you are fine. If air leaks occur, try wrapping electrical tape around the seam.
  5. Jul 5, 2011 at 5:56 PM
    TacoMal
    California
    He said if it is in his main warehouse it would be faster. I'm going in tomorrow to find out. They are closed now.
  6. Jul 5, 2011 at 6:08 PM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Check with any parts stores like autozone or pepboys? Sometimes you can get a part there quicker. You can also try online and get next day if the dealer can't help. If worse comes to worse, take one of the bolts out and go to HD or Lowes and get a similar bolt from among the hundreds there as a temp bolt if you end up having to wait a few days.
  7. Jul 5, 2011 at 6:20 PM
    TacoMal
    California
    Thanks for the replies guys. I was able to get it back together. It ran a little high at first, but I had just cleaned the mass air flow and the throttle body and I re,ember someone saying it might idle a little high at first. I out some electrical tape around the top seam and hit the throttle a few times. Idle came down and no cel light so I think I'll be ok.... Now I don't even wanna start my spark plugs lol.
    Never done them before. Did the oil (that's all I've ever done on my trucks), front diff, t case and rear diff fluid changes. Never done those before. Everything was going so well dammit!
  8. Jul 5, 2011 at 6:38 PM
    KenLyns
    Belly of the Beast
    The bolt sheared at 9 ft-lb? Double-check your torque wrench and hold the rachet head while torquing.
  9. Jul 5, 2011 at 7:00 PM
    TacoMal
    California
    I'll do some searching tomorrow morning. Hopefully I can find it without having to go to the dealer. 3 spark plugs down, 3 to go! Thanks for all the help!
  10. Jul 5, 2011 at 7:02 PM
    TacoMal
    California
    Yeah. I was pissed! I'm sure it was user error though. Oh well, live and learn. Learning as I go. The afternoon was going too well for something not to get screwed up!
  11. Jul 5, 2011 at 7:07 PM
    krans
    krans Well-Known Member
    Kenny
    Huntington beach/ West min duh
    09 Sport mall crawler
    Icon extended travel with resi front and rear,Camburg UCA, All pro standard leaf pack, Fogs anytime, General grabbers AT2,Custom stainless steel brake lines,bed box, Bestop soft top,50' light bar, amber rigid pods,CBI ditch mounts with LED pods,TRD intake,Anti dark hoodlights/rock light/LED whip,FX-R retros and Gibson catback..more mods to come
    Where in california are you? If the dealer has to order the bolt I know this place in garden grove that has pretty much everything in stock.
  12. Jul 5, 2011 at 7:23 PM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Junk yard is always another option besides the other places me or others have mentioned above.
  13. Jul 5, 2011 at 7:24 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    X2
  14. Jul 5, 2011 at 7:42 PM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    Fastenal is a company around here that had all the stuff i needed to remove a broken stud from my bronco II. Got the easy out, tap, and new bolt. I'm sure they would have what you need. Any industrial fastener supply should have it. NAPA auto parts is also a good choice if they operate in your area.
  15. Jul 5, 2011 at 8:07 PM
    TacoMal
    California
    Thanks guys. I'm in the bay area. I will check the local places first and see if they have it. Just buttoned everything back up and took it for a drive. No issues so if the worst case scenario is that I have to wait a week, I'm pretty sure I will be okay.
    Krans, do you have the name of the place in garden grove? Maybe I will give them a call also if I can't find it local.
    Thanks!
