Help...bolt is spinning with the nut
Discussion in 'Suspension' started by BenTheMan, Apr 11, 2015.
  1. Apr 11, 2015 at 6:01 PM
    BenTheMan
    BenTheMan [OP] Well-Known Member
    Ben
    Portland
    2012 TRD Sport 4x4 AC
    Truck Nutz
    So I got my OME suspension from wheelers today. Driver side went in no problem. I put my passenger side strut in and while I was putting the top nuts on I realized I forgot to put the spacer in. No problem right? I only had them about half way on so I start to take them off. I get the outer two off then start to work on the one closest to the engine. Well the bolt is now spinning with the nut. I can't tighten it or loosen it. What do I do?! (I realize now that my title sucks.)
  2. Apr 11, 2015 at 7:53 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Thin grinding disc. Cut nut and bolt off.
    Take it apart and put in a new top cap or tack weld new bolt to top cap.
