HELP!!!! Ball joint replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jfoster92, May 13, 2018.
  1. May 13, 2018 at 12:43 PM
    jfoster92
    jfoster92 [OP] Well-Known Member
    Justin
    Farmerville, la
    08 Tacoma prerunner v6/manual
    Currently trying to change all four ball joints in my yard. I rented a ball joint press from oreillys but it’s not working very well
  2. May 13, 2018 at 12:47 PM
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    What are you having issues with? Right size adapters?
  3. May 13, 2018 at 12:47 PM
    Lord Humongous
    AZ
    Also are you installing or removing in that pic?
  4. May 13, 2018 at 12:50 PM
    HCJ
    HCJ Well-Known Member
    Virginia --> Texas
    '05 Taco with not enough miles
  5. May 13, 2018 at 12:52 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    When removing, hit the LCA with a torch. When reinstalling, put the BJ in the freezer for an hour. Right before install, heat the LCA with a torch and the cold ball joint will go in a lot easier.
    Also power tools are your friend.
    https://youtu.be/x_JhoRVU1-w
  6. May 13, 2018 at 1:29 PM
    jfoster92
    Justin
    Farmerville, la
    Adapters. I can’t make any variation do any good. It only came with 3 sleeves and 2 plates
  7. May 13, 2018 at 1:29 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Did you rent it? The one we rented from autozone came with a bunch of adapters.
    wilcam47 and Lord Humongous like this.
  8. May 13, 2018 at 1:36 PM
    Lord Humongous
    AZ
    I'd go back and see if they have a master kit. Like @EatSleepTacos said your probably need something else. you could probably use what you have to get it out but risk marring up the new replacement ball joints with out the right adapters. I'd lend you my kit if you youre in phx?
    EatSleepTacos likes this.
  9. May 13, 2018 at 2:01 PM
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    If they don’t have the master kit, I’ve herd that harbor freight has a kit with the correct size cup to press the ball joint
  10. May 13, 2018 at 3:46 PM
    jfoster92
    Justin
    Farmerville, la
    I found a master kit. Still having a hard time figuring how to arrange everything to press out the upper. Preventative maintenance gone to shit on sunday
  11. May 13, 2018 at 3:58 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Are you trying to use the ball joint press with only a wrench? When space is limited that I can't use an impact gun, I have used a 2 foot long ratchet and it still can be a total nut buster turning the ball joint press. I think you need more leverage.
  12. May 13, 2018 at 4:10 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    When we pressed out the upper, We didn't have anything on the top. On the bottom we just had one large cup.
  13. Aug 6, 2019 at 8:29 AM
    Carl_z33
    Carl_z33 Well-Known Member
    Carl
    2014 Toyota Tacoma TRD OR 4x4 DCSB
    What size receiver did you use? I’m having trouble removing mine & I rented the kit at auto zone
  14. Aug 6, 2019 at 8:44 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I haven’t the slightest clue. Just used the one that fit. Sorry I can’t help more.
    Superdave1.0 likes this.
  15. Aug 6, 2019 at 8:49 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    only thing i can say is make sure theres a sleeve big enough to go over the bigger side of the ball joint so you dont have the sleeve on the ball joint, and use a pipe to get more leverage. Should just screw down and pop out the bottom. Ive never had to use torch or freeze anything. It may help though...
  16. Aug 6, 2019 at 8:52 AM
    Carl_z33
    Carl
    It’s either bigger or smaller & the one that works best, ends up slipping off.
    The receiver socket doesn’t have enough room to settle down
