Help, Alignment Experts: Toe-Out Wear?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dirty Harry, Mar 15, 2018.
  1. Mar 15, 2018 at 2:54 PM
    Dirty Harry
    Dirty Harry [OP] Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    Ever since I've had my truck I've been noticing premature wear on the outer tread of the tires. I definitely take turns a little to sharp, but this is due to my trophy truck lifestyle. Doe you suffer from the same? Can I tell my local shop to adjust that camber and save my tires? Help!
  2. Mar 19, 2018 at 6:32 AM
    Dirty Harry
    Andrew
    SW Florida
  3. Mar 19, 2018 at 6:40 AM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Toe out wear would be on the inside edge of the tires, not the outside. Also no "street" alignment is going to be toe out.
    You could just be wearing the outside edges from aggressive turning, or there is an alignment issue that is not toe out. Are these the tires that came with the truck or did you pick out something aftermarket?
    Pictures might help too.
  4. Mar 19, 2018 at 7:01 AM
    Dirty Harry
    Andrew
    SW Florida
    That's what I'm afraid of...
    The tires I've got now are Falken Wildpeak AT3W. 265/75 16.
    Stock tires were doing it too. Maybe even worse. I'll try to update with a pic from lunch.
  5. Mar 19, 2018 at 9:40 AM
    awdvkd115
    awdvkd115 Well-Known Member
    Bud
    2017 Tacoma TRD OR
    Toytec lift, White Knuckle sliders, RCI Armour, ECGS (Nitro Gears), Victory 4x4 Striker Front bumper, Smittybilt X20 10K winch, Dobinson snorkel, Spidertrax 1.25 spacers and 255 R80 16 BF Goodrich KM2s.
    Alignments have three settings, camber, caster and toe. Caster does not cause tire wear it's mostly a handling adjustment. Camber is the tilt of the tire towards the engine or out toward the fender and is a tire wear setting. Toe is the setting of the tires straight ahead with a small amount of adjustment pointing them towards or away from each other and will cause tire wear. Since it is happening on both tires I doubt it is the camber. Sounds like you have to much toe-in and the tires are wearing on the outside of the tires. Toe can be knocked out of adjustable very easily on off road vehicles. If you plan on owning the truck for a long time and offroad I would suggest going to a local Firestone dealer purchase their lifetime alignment and just have your alignment checked periodically. Hope this helps!
    Dirty Harry[OP] and FlyFisherCJ like this.
  6. Mar 19, 2018 at 10:30 AM
    Dirty Harry
    Andrew
    SW Florida
    I've actually got a lifetime alignment service at my local shop. I just wanted to make sure I was asking them to do the right thing (camber vs toe-wise) in order to keep this from prematurely wearing my tires.
  7. Mar 19, 2018 at 11:20 AM
    awdvkd115
    Bud
    2017 Tacoma TRD OR
    I left my truck at factory camber, 3.5 caster and 0 toe. Yes it wonders a little on a heavy crownded road but suits me. I also have a 2in lift and SPC UCA's. Good luck!
    Dirty Harry[OP] likes this.
  8. Mar 19, 2018 at 2:45 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    How often are you rotating?
    What pattern are you using for tire rotation?
    Factory wheels?
    Wheel spacers?
    Factory alignment is more or less:
    +2.0 caster
    +0.50 camber \ /
    +0.01 toe / \
    Jumpman23 likes this.
