Help adding a digital speedometer for a new driver
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CMilly, Mar 21, 2022.
  1. Mar 21, 2022 at 11:40 AM
    CMilly
    CMilly [OP] New Member
    Craig
    2014 Tacoma Pre-Runner
    n/a
    Hello!
    First timer here. I have a new driver just learning to drive and they are spoiled with my 'heads up' display. However I'm planning on letting them drive my '14 Tacoma and they asked about a digital speedometer. SMH. Anyway, seems simple enough to add. I found a small simple one with a nice unobtrusive mount on the column. My only problem is locating a Vehicle Speed Sensor wire to tap into. I can't find anything online. Can someone here please point me in the right direction? Would i need to tap into the back of the cluster or the dr side junction box? Which pin?
    I can send pics if needed. Thank you so much in advance!
    -Craig
  2. Mar 21, 2022 at 11:45 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Welcome to TacomaWorld. I'd look for one that hooks into the OBD2 port, they are plug-and-play and pretty cheap.
    Something like this one (though I am not endorsing this product at all, just using as an example):
    https://www.amazon.com/iKiKin-Display-Speedometer-Windshield-Projector/dp/B07MCWG3JT
    Edit: Just remembered something else. If you have an old deactivated cell phone collecting dust you could use that + a common Bluetooth OBD2 reader + something like the Torque app to also display a digital speedo.
    VXEric likes this.
  3. Mar 21, 2022 at 12:22 PM
    CMilly
    Craig
    n/a
    Thank you, that would have been the smartest and easiest solution. Unfortunately I'm over ambitious and thought with a little additional work, it could be more perm and less exposed wires. I already got the GlowShift Guage and pod. Now I'm stuck and regretting that decision.
    And I do have several old phones that could have repurposed for this, ugh.
  4. Mar 21, 2022 at 5:38 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    A little pricey but since you already have the glowshift gauge you could use this.
    https://www.glowshiftdirect.com/gps-speedometer-sensor-kit/
    I'm not sure what kind of input your aftermarket speedometer needs but there is 2 wires on the meter that generate a 0-12v square wave based on vehicle speed.
