HELP!!!! 2004 Toyota Tacoma Headlight Recommendations
Discussion in '1st Gen. Tacomas (1995-2004)' started by jkmoody, May 7, 2019.
  1. May 7, 2019 at 6:14 AM
    jkmoody
    jkmoody [OP] Member
    2004 Toyota Tacoma Xtra Cab Prerunner
    I have a 2004 Toyota Tacoma that needs all headlights replaced (signal lights too). So I wanted to reach out on here to see if anyone had any recommendations on what I should replace the factory ones with. Thanks in advance and its greatly appreciated!
  2. May 7, 2019 at 6:22 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
  3. May 7, 2019 at 6:57 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
  4. May 7, 2019 at 7:08 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    is this an emergency situation?
    I have heard they (forum mods) don't like the big HELP in titles unless it is real emergency
    otis24, jbrandt, Sebz13 and 3 others like this.
  5. May 7, 2019 at 7:20 AM
    adamdsgn
    adamdsgn Well-Known Member
    Adam
    2003 Tacoma Double-Cab - TRD/4x4
    I just replaced my '03 headlights with the most expensive version they offer on www.rockauto.com. I also ordered new fillers, side marker lights and lower blinker lights. Makes a world of difference. I would also suggest replacing the craptastic bulbs that come in the headlights once you get them installed.
  6. May 7, 2019 at 1:35 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    I also did this, although the bulbs that came with mine are pretty solid
    Ritchie likes this.
  7. May 7, 2019 at 1:51 PM
    FlyinHawaiian21
    FlyinHawaiian21 Active Member
    Mitchel
    Maui, HI
    2003 Silver Tacoma TRD
    Toytec BK9504 Pair of ditch lights Sony AX-100 10 inch Sony Xplod 17 x 8.5 SCS Ray 10's 285/70/r17 Goodyear Duratracs Spidertrax 1.25" Spacers A.R.E Camper w/ yakima racks
    Kolter45 and DashMaple like this.
  8. May 7, 2019 at 1:53 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Buy OEM housings. Find some used in the For Sale section. Then just upgrade to a brighter bulb if you want more output. I would recommend staying away from aftermarket houseings due to being cheaper and having leaking issues over stock.
  9. May 7, 2019 at 1:55 PM
    DashMaple
    Louisiana
  10. May 7, 2019 at 2:04 PM
    FlyinHawaiian21
    Mitchel
    Maui, HI
  11. May 8, 2019 at 12:42 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
  12. May 8, 2019 at 2:04 PM
    FlyinHawaiian21
    Mitchel
    Maui, HI
    It comes with parts to hold it in place, its basically a lock ring.
    chrslefty[QUOTED] likes this.
  13. May 8, 2019 at 5:21 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    Stick to the OEM version from Rock Auto for headlights. Mine came with 8k Sylvania bulbs and delivered for $63.00.
    The corner lenses can be had (painted) for $14.00 each, not including tax and shipping.
    Good luck.
  14. May 8, 2019 at 5:24 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    I put Anzo headlights in my 99 and was pretty happy with them. Had to replace the hazy stock housings.
  15. May 8, 2019 at 11:10 PM
    CrankTank
    CrankTank New Member
    2002 Tacoma DC TRD AT
    TRD SC 7th Inj | FOX Bypass | Total Chaos | Deaver | Relentless | CBI
    Another vote for OEM- nothing better in the long run.
  16. Nov 23, 2021 at 5:39 PM
    Brandoncody88
    Brandoncody88 Member
    Brandon
    2003 green Tacoma 4x4
    Leveled on 33s
    how did you splice in the halo? And used your parts list and now the headlights don’t work but the projectors do? I’m confused, I used everything in your parts list and the after markets housing and lights worked before changing the housing. Just need some direction on what to look for
  17. Nov 24, 2021 at 10:24 AM
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    Def the retrofitsource is the way to go. They have a good black friday deal going if you still need parts.
  18. Nov 24, 2021 at 12:01 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    *pushes glasses up on nose*
    I know this is an older post but I want to clear up some potential confusion.
    Rock Auto doesn't sell "OEM" parts. They sell "OEM Equivalent" parts. True OEM is going to cost 2-3 times as much and is generally only available from Toyota dealers.
    That said, the CAPA certified TYC housings are likely to be the best "OEM like" housings. I had great experiences with mine. They really are indistinguishable from the OEM that I replaced with them. Definitely spend the extra few bucks for the CAPA certified ones, they're only a few bucks more. The CAPA cert is effectively the same QA/QC process the Toyota factory demands from its OEM supplier.
    If you're going to do the retrofit, it's debatable if the CAPA cert is worth it, but since it's only a few bucks more, seems like it'd be worth it as the general fit/finish (not just the quality of the reflectors) is going to be better too.
    For the love of got don't buy true OEM housings just to cut them up for a retrofit.
    Madjik_Man likes this.
  19. Nov 24, 2021 at 12:05 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I don't see the issue. You get a housing good for 15 years and you are adding superior lighting when done right.
  20. Nov 24, 2021 at 12:13 PM
    jbrandt
    Justin
    When doing a retrofit, the "superior lighting" is coming from the retrofit, not the housing it's placed in. Aside from potential leaks from inferior lens seals, the housing is pretty much irrelevant.
    As I said, the TYC CAPA certified housings are about as equivalent to true OEM as you can get, at like 1/4 the cost.
    But if you want to cut up your $180 (each) housings, be my guest, but to me that seems like kind of a waste.
    https://parts.camelbacktoyota.com/v...--2-7l-l4-gas/electrical--headlamp-components
