Helmholtz resonator in exhaust
Discussion in 'Technical Chat' started by cmj, Jan 13, 2016.
  1. Jan 13, 2016 at 1:55 PM
    cmj
    cmj [OP] Well-Known Member
    Oregon
    98 Tacoma 4x4
    Who's tried this?
    In case you're wondering, helmholtz resonance is a phenomenon where a cavity resonates at certain frequencies of sound.
    http://docs.lib.purdue.edu/cgi/viewcontent.cgi?article=2200&context=icec
    http://www.diracdelta.co.uk/science/source/q/u/quarter wave tube/source.html#.VpbfN7x-jdk
    By designing a helmholtz resonator in to an exhaust system, you can eliminate particular frequencies of sound depending on the shape, volume, and temperature of the gas.
    I've researched and found that lots of car guys do it to kill drone on their 911/vette/g35 or whatever. The simplest idea is to create a cavity that is a quarter wavelength in length of the peak drone frequency. That way, the sound waves travel a total distance of a half wavelength (putting the wave out of phase with the target frequency) and cause destructive interference to eliminate the noise.
    I measured the drone on my truck at various speeds with my laptop and plotted amplitude vs log frequency. At 70mph the drone peaks at 89 Hz. Real annoying on the long drives.
    Screenshot%202016-01-13%2013.37.40_zpsnd_630d8ab5d9110af124390ebf7918bd5b08bc5831.jpg
    Here's the basic calculation
    L = 1/4*lambda
    L = 1/4 * v_sound / f_peak
    v_sound depends on temperature. Assuming 200*F, v_sound = 1275 ft/s
    L = 1/4 * 1275 ft/s / (89 1/s) * 12 in/ft = 43 in
    43 inches is LONG, but there is enough space under the truck.
    One concern is that the drone appears to be pretty wide band, which means that if the resonator is to "peaky" it's not going to do a whole lot. Looking for a "low" Q factor resonator, but this is not easily calculated. It seems like it will be just trial and error with all the variables involved.
    I guess what I'm looking for is thoughts/advice/first hand knowledge on the subject. Surely someone has tried this on their tacoma.
    Speedytech7 and Biscuits like this.
  2. Jan 14, 2016 at 4:28 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
  3. Jan 16, 2016 at 5:25 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Are you shit'in me? The most technical TW gets with exhaust sound, is after asking for a "which one" opinion, is listening to exhaust sounds on you tube videos.
