Hello all, it’s been awhile...window regulator, genuine Toyota or ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by roguewaave, Mar 24, 2021.
  1. Mar 24, 2021 at 3:44 PM
    roguewaave
    roguewaave [OP] Well-Known Member
    Texas/Maine
    stock
    stock
    My daughters 2002 Tacoma 2 door right side window regular has failed, I’m wondering if an aftermarket regulator will work fine and is it of good quality? What brand? Rockauto shows many different brands, none of which seem to be OEM Toyota part.
    Thoughts?
    thanks
  2. Mar 25, 2021 at 8:36 AM
    roguewaave
    Texas/Maine
    stock
    stock
    Guess not....
  3. Mar 25, 2021 at 8:42 AM
    tntacomaguy
    tntacomaguy Well-Known Member
    From my personal experience, I recommend OEM. My driver window regulator has been replaced 3 times, the first 2 were within a few months of each other, the last time I used OEM and its been 3-4 years and its still going strong.
    Darrell942 and Hamer95USA like this.
  4. Mar 25, 2021 at 9:17 AM
    roguewaave
    Texas/Maine
    stock
    stock
    Thank you, really appreciate that.
  5. Mar 25, 2021 at 12:59 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Going to come a Time soon when New Toyota Parts go obsolete for older vehicles if you can still get one I would
    Just how as yours failed??
    I might go used before Rock Auto.
  6. Mar 25, 2021 at 1:00 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    BartMaster1234 likes this.
  7. Mar 25, 2021 at 1:34 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I do! OP Message me if you're interested. OEM.
    neucase_fredo likes this.
  8. Mar 25, 2021 at 7:28 PM
    roguewaave
    Texas/Maine
    stock
    stock
    I wish I would have known sooner dang it but I already ordered.
    Next time!
    Part Number
    Part Name Price Quantity Total
    69802-35090 Window Regulator $96.22 1 $96.22
    Subtotal: $96.22
    Estimated Shipping to 78654 via Standard Shipping: $10.41
    Total: $106.63
  9. Mar 25, 2021 at 10:21 PM
    Davesbruh
    Davesbruh Well-Known Member
    Dave
    Orange County
    02 Prerunner double cab that identifies as 4x4 and is transitioning
    Bootleg special
    I put in a rock auto one almost 2 years ago and it’s been working great. Only issue was the wiring harness was not correct so I had to cut and solder the old one on. Worked out fine.
  10. Mar 25, 2021 at 11:54 PM
    neucase_fredo
    neucase_fredo Active Member
    Alfredo
    I’m interested in drivers side if available
  11. Mar 26, 2021 at 12:51 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I'll take a look
  12. May 13, 2021 at 7:06 PM
    Darrell942
    Darrell942 Active Member
    Darrell
    Byron Georgia
    2000 Toyota Tacoma Prerunner Extra Cab 4cyl 2.7 Ltr
    None, why mess with a good thing
    Drivers Window Issue: This is a timely discussion, assuming I am correct and window regulator is the answer,
    2000 Toco, just a few hours ago as I was closing the powered drivers window when it completely closed the motor continued to run.
    - I stopped, backed it down several inches and attempted to roll it back up.... no glory.
    - However I was able to slowly work the window back up manually using my hand and the power window button. Slow process.
    here's MY question..... is that a failed window regulator? IF SO .... is that the part number above under "roguewaave" post? BartMaster1234 ?
    Thanks in advance for the insight
  13. May 14, 2021 at 9:55 AM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    Put an aftermarket in our 99 Accord, no problems 5 years later FWIW
  14. May 16, 2021 at 12:36 PM
    Darrell942
    Darrell
    Byron Georgia
    roguewaave, How did your install go?
