Heavy Grease Seeping from Ball Joint
Discussion in '2nd Gen. Tacomas (2005-2015)' started by UOFan, Mar 28, 2020.
  1. Mar 28, 2020 at 10:26 AM
    UOFan
    UOFan [OP] Well-Known Member
    Bryan
    NC
    1994 Single Cab DLX, 2013 TRD Sport, 1999 Dodge 2500 360 V8
    5100 Lift + AAL
    Noticed today that both my ball joints are leaking grease. The drivers side slightly, but I pulled a quarter sized chunk of dirty grease from the passenger side.
    Previous threads on this topic have stated nothing to worry about, a little seepage is natural as mileage grows (I’m at 66k). However someone mentioned to make sure it wasn’t “globs of grease”. I need a second opinion as to whether or not this constitutes a glob a grease...thanks!
    Pictures -
    passenger side AFTER removing quarter size of grease and throwing it away:
    drivers side:
  2. Mar 28, 2020 at 11:08 AM
    DJSpeed
    DJSpeed Well-Known Member
    as long there is no play that is normal.
    especially if u lift your truck. u will see even more leakage
  3. Mar 28, 2020 at 12:10 PM
    UOFan
    Bryan
    NC
    5100 Lift + AAL
    Good to hear. I’ll check for play this week. I have 1.5” on front, 5100s at lowest setting with new coils.
  4. Mar 28, 2020 at 12:38 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Remember, on non-greaseable joints like that, the grease that leaks out is no longer available to lubricate the joint. Once it's gone, your joint will wear faster. Worse yet, if the grease can leak out, water and dirt can leak in. This just makes a bad situation worse.
    UOFan[OP] likes this.
  5. Mar 28, 2020 at 12:54 PM
    UOFan
    Bryan
    NC
    5100 Lift + AAL
    Yeah it’s not ideal. I’ll troll around looking for ways to slow this. I remember reading through a thread where someone was asking if they could inject the top of the boots with grease.
  6. Mar 28, 2020 at 1:15 PM
    Too Stroked
    Tom
    That rubber boot looks pretty crispy. I don't think poking a hole in it or trying to get a grease needle in there is going to do it any favors.
  7. Mar 28, 2020 at 4:22 PM
    UOFan
    Bryan
    NC
    5100 Lift + AAL
    Looks like it’ll be safe as long as I continue to monitor the wheel. I found some new complete LCAs for $200...not as bad as I would have thought.
  8. Mar 28, 2020 at 4:27 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Replace the joint.
  9. Mar 28, 2020 at 4:37 PM
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    That’s normal. If you want you can buy a needle that attaches your your grease gun. Just poke it in the boot and regrease it
  10. Mar 28, 2020 at 4:49 PM
    Too Stroked
    Tom
    Just be careful with aftermarket (Dorman, cough, cough) Lower Control Arms. Although OEM costs more, there are some pretty significant differences in quality and part life.
  11. Mar 28, 2020 at 5:12 PM
    UOFan
    Bryan
    NC
    5100 Lift + AAL
    Maybe I could even melt the boot hole back together afterwards. If I go this route, thanks for the input, we will see..
    Having trouble finding new OEM LCAs with LBJs already pressed in. I’ll stay on the lookout.
  12. Mar 29, 2020 at 5:49 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    It's a sealed part if grease can leak out water can leak in it's a lot thinner than grease poking a hole in it just makes it worse. If it's "normal" mine should be greasy at a 125K. You do realise "lifting" a truck changes the steering geometry so that plays into this also.
  13. Mar 29, 2020 at 6:10 AM
    UOFan
    Bryan
    NC
    5100 Lift + AAL
    Yes I'm aware about the geometry change. I will probably take it in for an alignment soon here and get a second opinion.
