Heater valve cable not moving
Discussion in '1st Gen. Tacomas (1995-2004)' started by karma301, Dec 12, 2021.
  1. Dec 12, 2021 at 6:30 AM
    karma301
    karma301 [OP] Member
    2002 Green Tacoma PreRunner
    The cable has been out for over a year now, and it was not fun last winter. The valve itself works fine and I can manually change from A/C to heat at the actual valve, but the knob won't move the cable at all. As the temperature fluctuates a lot here I'd rather not have to get out and change it each time. How do I diagnose and fix it? Any help is appreciated.
  2. Dec 12, 2021 at 6:56 AM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    Any chance that you spray some WD-40 into the cable?
  3. Dec 12, 2021 at 6:56 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    If your truck has a round knob temperature selector it uses an electronic actuator that has a servo motor and plastic gears to move the valve on firewall.
  4. Dec 12, 2021 at 7:01 AM
    karma301
    Hmm, the cable has some slack when I pull on it so I'm not sure if that's it, but I'll keep that in mind, thanks.
  5. Dec 12, 2021 at 7:03 AM
    karma301
    Mine looks like this so I don't think it's the one you're referring to? upload_2021-12-12_9-2-15.jpg
  6. Dec 12, 2021 at 7:10 AM
    Black DOG Lila
    Virginia
    That is all servo actuated HVAC
    Earlier models have sliding levers and cable HVAC controls. Yours are electric.
  7. Dec 12, 2021 at 7:13 AM
    karma301
    Ah ok, thank you! Any leads on how to fix/ replace it?
  8. Dec 12, 2021 at 7:17 AM
    Black DOG Lila
    Virginia
    YouTube has many 1st gen Tacoma HVAC repair vids easily found using the search.
  9. Dec 12, 2021 at 7:23 AM
    karma301
    Thank you I appreciate the help! I didn't know where to look so this helps a lot.
  10. Dec 12, 2021 at 7:25 AM
    Black DOG Lila
    Virginia
    Around 3 minutes in this video shows the cable actuator
    https://youtu.be/9f2VqkdiJwo
    karma301[QUOTED][OP] likes this.
  11. Dec 12, 2021 at 7:45 AM
    Black DOG Lila
    Virginia
  12. Dec 12, 2021 at 8:06 AM
    1997tacomav6
    Denver
    Go to a salvage yard and you can get the complete gears and mechanical parts 95-97
  13. Oct 30, 2023 at 10:52 AM
    ChiquitoTruck
    ChiquitoTruck Active Member
    Melina
    New Mexico/South Texas
    1999 Tacoma SR5 3.4
    Did you ever find the fix for this?
  14. Oct 30, 2023 at 12:32 PM
    Taco_Love
    Taco_Love Well-Known Member
    99 reg cab 4x4
    I had this problem where my dials seemed to be stuck, there is the cable that you've identified in your engine bay and there is also a cable underneath the glove box area ( you gotta tear into it pretty far, my buddy did this for me). The way I fixed this was to spray fluid film in the sleeves of both these cables while you have someone on the HVAC controls moving them back and forth repeatedly (making sure not to spin it so far that it skips gears). After enough persuasion my controls now work pretty decently.
    We also found an old wasps nest in my heater core area, not sure how those little shits got in there but I'm sure that wasn't helping with my knob movements.
    ChiquitoTruck likes this.
  15. Oct 30, 2023 at 7:31 PM
    rrock99
    rrock99 Member
    1999 Tacoma Prerunner
    My 99 has the exact same knob. Cable acuated. I replaced the valve and it turned just fine afterwards.
  16. Nov 2, 2023 at 7:45 PM
    ChiquitoTruck
    Melina
    1999 Tacoma SR5 3.4
    Thanks for the reply. Looks like mine is the same issue. Replaced the firewall valve and it didn’t change a thing. But once i started spraying some lube into the cable you mentioned, it started getting easier. Thanks homie.
    Taco_Love[QUOTED] likes this.
  17. Jan 6, 2024 at 2:11 PM
    AZE
    AZE New Member
    Thanks for the insight on this topic. Question...is the blend door actuator the same part that controls the cable that is attached to the temp control valve under the hood at the firewall? I have a 2002 Sequoia that doesn't get warm air all of the sudden. I checked the valve and it rotates easily. The cable, however, doesn't move up or down. I've started spraying silicon spray, per a different thread, to see if that will help. As some on this thread have described, I'm not hearing the grinding gears when I switch the temperature control knob from cold to hot or vice versa. Thank you for the insight.
