Heater core flush
Discussion in '2nd Gen. Tacomas (2005-2015)' started by patos tacoma, Jan 7, 2021.
  1. Jan 7, 2021 at 11:50 AM
    patos tacoma
    patos tacoma [OP] Well-Known Member
    2010 Silver Tacoma TRD Sport
    So there I was watching Heater Core Flush videos, and saying, I can do that......
    So I ran to HD , got my supplies and this morning, started on the project......
    As always, nothing ever goes like on the videos.......got one hose off and the other one won’t budge.........they’re original....2010 taco, 214k
    is there any other way to resolve my dilemma , other than cutting the hose.....getting a new elbow hose and making the project bigger.....(don’t really want to do that).
    found a small shop that does a lot of work, they want $175 to do a coolant flush with chems , just not sure that cleans out the heater core.....
    as always, any help is appreciated.
  2. Jan 7, 2021 at 12:52 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Any particular reason why you want to flush the heater core?
    Is putting back together and leaving it alone an option?
    Or has one of the hoses been damaged?
  3. Jan 7, 2021 at 12:55 PM
    Noza
    Noza Active Member
    Flush your coolant system with the heat on high. It will flush your heater core at the same time.
    TRDSport10 likes this.
  4. Jan 7, 2021 at 1:28 PM
    patos tacoma
    Heat is a little weak......but mainly because I have flushed and reconditioned everything else.
    easy job to actually do, IF you can get hoses off.
    Pretty sure, coolant is original
    As of right now, everything back in its place, no damage done.......just didn’t want to give up.
  5. Jan 7, 2021 at 2:00 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Did you bleed system after flushing and refilling with coolant?
  6. Jan 7, 2021 at 2:12 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If you flush the coolant system you are also flushing the heater core.
    Hint: The heater core is part of the coolant system and always has coolant flowing through it regardless if the heat is on or not.
    Walldiver7 and 6 gearT444E like this.
  7. Jan 7, 2021 at 7:31 PM
    patos tacoma
    Then how, can the heater core get buildup , thus causing the heater to not put out a lot of heat......remember Toyota coolant is supposed to be long life
  8. Jan 7, 2021 at 7:39 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I didn't say that it could. I have never seen a blocked heater core in a vehicle with a properly maintained coolant system.
    Toyota Coolant is long life. I monitor the coolant in my vehicles every 6 months and have never renewed the coolant in less than 100K on any of them. None have ever had a blockage of any kind. And only 1 needed a thermostat at 80K.
    I'll promise you that the heater core see's flow 100% of the time the engine is running.
    Believe it or don't. Your call.
    6 gearT444E and TireFire like this.
  9. Jan 7, 2021 at 7:40 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If the coolant is maintained the heater core shouldn't get plugged but if it does the only way to properly flush it is to remove the hoses and flush it in both directions to get the crud out of it.
  10. Jan 7, 2021 at 7:41 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Because both the inlet and outlet are at the top of the core. Sediment (of any kind) goes in and settles at the bottom.
    I've noticed when doing a heater core replacement, often times the old core that comes out will be heavier than the new one in the box. Not a lot heavier but just enough to notice in your hands. Especially on old cars with high mileage.
  11. Jan 7, 2021 at 7:42 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Maybe there is another reason your heater is not warming up enough. Mine’s spicy hot.
    Jimmyh likes this.
  12. Jan 7, 2021 at 8:19 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    As others have said the heater core is part of your cooling system. The same liquid circulating through your radiator circulates through your heater core. When you flush your radiator cooling system the heater core is flushed also. However it is possible for your heater core to get clogged up. Sometimes a core can’t be unclogged and you have to replace it. A sign of a clogged core can be a reduction in heat , blowing warm not hot air. Another way to check the function of the core is with the engine running and at operating temperature, both heater hoses should be warm or hot to the touch. If one is cool or just slightly warm you probably have a clogged core.
    Jimmyh likes this.
  13. Jan 7, 2021 at 8:21 PM
    patos tacoma
    Will flushing the heater core individually flush out the sediment?
  14. Jan 7, 2021 at 8:22 PM
    patos tacoma
    Could be, here in Houston, folks don’t really pay a lot of attention to heaters, but I spend a lot of time in Dallas, which in the winter is easily 10deg colder.
  15. Jan 7, 2021 at 8:22 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes it should if it's not too bad but you still have some heat so flushing it should make it much better.
  16. Jan 7, 2021 at 8:27 PM
    patos tacoma
    Yup, that’s what I saw in Chris Fix’s you tube video, Now if only I can get the stuck hose off, I’ll get it done.....
    Today somebody recommended heating the hose with a hair dryer to help wiggle it off........and really the point of the the thread......how to get the hose off.
  17. Jan 7, 2021 at 8:35 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You can try grabbing it with a pair of pliers and gently twisting it, if the hoses are original and it comes down to cutting it they are relatively inexpensive you just have to match up what you need. Here's Rock Auto's listing of heater hoses.
  18. Jan 7, 2021 at 8:35 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Unless you want to risk doing a heater core.. you really need to slit the hose and peel it off. A new heater hose is way less time and money than removing the dashboard
    As far as the flush helping? Maybe, maybe not, i wouldn't get my hopes up too much.. but its still worth trying for sure..
  19. Jan 7, 2021 at 8:45 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Uuhh the pliers are exactly what you shouldn't use.. that'll crimp and deform the soft metal tube, then the clamp won't seal. I'd usually only use pliers on something cast aluminum. The tube metal is too thin..
    But i know what you mean, sometimes pliers will work and its all good.. but when it doesn't work out, you're kicking yourself
    Ive got a beefy 90 degree pick set specifically for working hoses loose, something to slip between the rubber and metal and work it around.
    Maybe bend a metal coat hanger 90 degs and carefully work it in there?
  20. Jan 7, 2021 at 8:54 PM
    Muddinfun
    Muddinfun Well-Known Member
    Hose removal tool.
