Heated Mirror Not Working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thefinalstraw, Nov 17, 2023.
  1. Nov 17, 2023 at 8:34 AM
    thefinalstraw
    thefinalstraw [OP] Well-Known Member
    2024 Underground TRD Sport 4x4 Premium
    Hi all. I have hit the limit of my own limited electrical repair and internet search capabilities, so hoping for some help from you kind folks.
    My (2016 TRD Sport) driver's side heated mirror recently stopped working - the passenger side still works fine. The fuse is good, so I pulled the mirror and there is no voltage there when it is turned on, so I pulled the door panel and there is also no voltage at the molex connector when it is turned on. So the problem lies somewhere between the switch and the connector inside the door. I'm confused what could cause this besides a wiring issue, since the passenger side still works. What are my next steps?!
    And this is doubtfully related, but just in case - I have had the opposite problem with the mirror motors for a year now - the driver's side motor works, but the passenger side doesn't. But that is far less inconvenient than the heater now that it is getting cold.
  2. Nov 17, 2023 at 9:52 AM
    caribe makaira
    Caribbean, Puerto Rico
    Verify the wires from the door O2 to the cab(driver's side kick panel) to IC3 from there to relay.
    Stevie17 likes this.
  3. Dec 13, 2023 at 5:42 PM
    Codzilla
    Codzilla Active Member
    SoCal
    16TRDORDCSB4X4
    Yes please!
    Any update OP? My 2016 OR drivers side just started taking longer than the passenger side to heat up. Hoping it’s an easy fix.
  4. Dec 13, 2023 at 7:40 PM
    ilikecider
    ilikecider Member
    3rd gen Taco MT 17
    CAI TRD
    ohh hey, this happened to me too recently. I will diagnose over the weekend.
  5. Dec 14, 2023 at 10:22 AM
    thefinalstraw
    nope, gave up and been using a credit card to scrape it lol.
    however i think i may have misinterpreted from this thread (https://www.tacomaworld.com/threads/2017-tacoma-heated-mirror-relay-location.782526/) that the relay is behind the heated mirror switch, which is in the center. but now that i read it again, i think it is behind the little coin tray and the AC switch is to the left of the steering wheel. @caribe makaira can you confirm? if so, maybe i'll try again. i just didn't feel like taking apart the center console.
  6. Dec 14, 2023 at 1:33 PM
    caribe makaira
    top relay
  7. Dec 14, 2023 at 6:52 PM
    Codzilla
    SoCal
    16TRDORDCSB4X4
    Yes please!
    DOH!! Thanks for the follow up.
  8. Dec 10, 2024 at 9:07 AM
    iNfectious
    iNfectious Well-Known Member
    Q
    Lone Star State
    '18 TRD Sport 4X4 DCSB
    Can you show me where IK2 for passenger side mirror heater? I checked the mirror heater relay and it's working. I also swapped relays to make sure.
  9. Dec 10, 2024 at 11:35 AM
    caribe makaira
    iNfectious[QUOTED] likes this.
  10. Dec 10, 2024 at 12:31 PM
    iNfectious
    Q
    Lone Star State
    Perfect thanks!
