Heads Up Display
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sb0623, Jan 9, 2024.
  1. Jan 9, 2024 at 5:23 AM
    sb0623
    sb0623 [OP] Well-Known Member
    DFW
    2022 Toyota Tacoma TRD Sport
    Limo tint, hitch step, grill guard, chrome running boards, running board lights, bed cover, dash cam, interior LED bulbs, MBRP cat back dual exhaust w/chrome tips, MillerCAT cat shield
    Has anyone on here installed one? If so, which one?
  2. Jan 9, 2024 at 5:46 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    I don't believe that this was an option for Tacomas.
    Our '23 Venza has it. You do realize that a 'heads up' display would require a new dashboard, as the image seen on the windshield is reflected from a display buried in the dash.
  3. Jan 9, 2024 at 7:11 AM
    KSchoppers
    KSchoppers New Member
    2022 Tacoma TRD OR
    There is at least one aftermarket option available, so no, you don't need a new dashboard.
    I tried out the one from the vendor with a four letter name. I didn't care for the positioning of the display in the windshield, so I'm working on an enclosure to put it more in the center. I don't think it's a very useful mod unless you just like to tinker.
    musicisevil likes this.
  4. Jan 9, 2024 at 7:26 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I had this on my Corvette and it came in handy when booking down the highway at ludicrous speed! But I just can't see how all the work and money would be worth it for a brick shaped pickup truck that starts to disintegrate at 90 mph.
  5. Jan 9, 2024 at 7:32 AM
    KSchoppers
    2022 Tacoma TRD OR
    I did like that I could leave another page on the gauges rather than speed and just use the HUD for the speedometer. But again, the location on the windshield is wrong. If it was centered and didn't require that reflective film, I would have kept it installed.
  6. Jan 9, 2024 at 7:32 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Not OEM but aftermarket.
    :puke:
    Chew and KSchoppers[QUOTED] like this.
  7. Jan 9, 2024 at 9:01 AM
    VicNic3
    VicNic3 Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
    alwaysHI and mic_sierra like this.
  8. Jan 9, 2024 at 9:03 AM
    Clearwater Bill
    Billy
    Largo Florida
    More details would be helpful.
    HisDad likes this.
  9. Jan 10, 2024 at 12:20 PM
    Deluxe714
    Deluxe714 Well-Known Member
    Vince
    Looks cool.
  10. Jan 10, 2024 at 12:31 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    something for nav would be nice
    I don't feel the need for telemetry data (maybe temps if I towed)
  11. Jan 10, 2024 at 6:48 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    I got a HUD from Amazon for $30, works great.
  12. Jan 12, 2024 at 1:47 AM
    RandallRaines
    RandallRaines New Member
  13. Jan 12, 2024 at 8:15 AM
    VicNic3
    GA
    You have to fine tune on HUD.I drove and stopped and made adjustments till matched.
    RandallRaines[QUOTED] likes this.
  14. Jan 12, 2024 at 8:41 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    I have this one too. It's not bad at all (2019 MY). I'd buy it again. Here are the pros:
    • The 2018+ units are hardwired in, compared to the early year trucks that connect to the OBD port (verify),
    • The "door ajar" notifications are great,
    • The tire pressure monitor alerted me of a leak before the OEM Guage cluster did,
    • I like that I can turn off all the LEDs at night if they're too bright,
    • It DOES have a digital temperature selection, which, per the manual, is the Water temperature readout,
    • The rev limiter tells me when I'm throttling in excess,
    • I'm pretty sure there's an ice warning ⚠️ for Temps below freezing.
    The cons are:
    • I noticed a slight buzz at first, but not noticeable anymore,
    • The speaker is slightly lower volume,
    • The hardwire cable needs to be removed when you flash the truck (OVTune does not work if it is plugged in),
    • The reflective windshield tape is too big, and should be trimmed before installing (minor issue).
    :thumbsup:
    musicisevil and VicNic3[QUOTED] like this.
  15. Jan 12, 2024 at 8:47 PM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    If it's not projecting relevant data in your line of sight, what is the point?
    Chew likes this.
  16. Jan 13, 2024 at 12:47 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Cool factor is about it
  17. Jan 13, 2024 at 5:21 AM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    I saw this thread and was kind of interested, and I did a search of the product and found that the vendor ktjo4x4 is banned from the forum for various reasons. So buyer beware.
    Chew likes this.
  18. Jan 13, 2024 at 5:58 AM
    Buck Henry
    The HUD on my 09 Corvette was pretty simple. It had a "street mode" that just had speed and RPM's and "track mode" that added coolant temperature and oil pressure.
  19. Jan 13, 2024 at 6:30 AM
    ace_10
    Rural NoVA
    Right. And that information is projected directly into your line of sight where it's supposed to be.
    KSchoppers likes this.
  20. Jan 13, 2024 at 10:56 AM
    RyanDCLB
    4/19 DCLBOR
    It's nice that I can check my coolant temp in the left corner of my windshield while I'm towing a travel trailer. :notsure:
    Not gonna lie. I have many products from KTJO , and had them for years. Nobody else makes them. Some of my favorite mods. All of them add another level of convenience. Cool factor as well. :cool: IMO, these should be factory:
    • Door handle bowl lights,
    • Driver side grab handle,
    • Folding Mirrors,
    • One touch rear window switch,
    • One touch passenger window switches,
    • Heads up display
    I understand she was banned trying to sell custom Tacoma products here in this niche market. Fortunately, I wasn't caught up in that fiasco. I waited until the products were complete and vetted. No pre-orders here.
    Tacomaworld helped get her foot in the door. No doubt, she's probably grateful to this forum. It's not often that you get a chance to quit your day job and work on your hobby. Yes, some people were upset because of delays and problems with prototypes. It was probably a blessing in disguise that she was banned, so she could focus on bringing the products to the mainstream. :boink:
    Anyway, all these products that I have are performing as designed. Again, nobody else makes them! They're definitely practical and cool. I'd buy again. YMMV. My $.02 :hattip:
