Headlight Wiring Diagram Needed
Discussion in '1st Gen. Tacomas (1995-2004)' started by LoriB01, Oct 12, 2018.
  1. Oct 12, 2018 at 4:03 PM
    LoriB01
    LoriB01 [OP] Member
    Lori
    Atlanta
    99 Tacoma 4 cyl, 2.7, 4x4, manual
    Does anyone have a headlight diagram for '99 Tacoma?
    My headlights don't work except when I pull back the stalk (flash). I have replaced the bulbs, relay, and controller. The fuses are good, the relay clicks, no headlights.
    Thanks
  2. Oct 12, 2018 at 4:09 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    might be your switch
  3. Oct 12, 2018 at 4:12 PM
    LoriB01
    LoriB01 [OP] Member
    Lori
    Atlanta
    I changed that out, the part was called a controller so that's what I called it but, yes, it's a switch. Sorry to be confusing.
  4. Oct 12, 2018 at 4:33 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
  5. Oct 12, 2018 at 5:33 PM
    LoriB01
    LoriB01 [OP] Member
    Lori
    Atlanta
    Thank you very much. No DRL, I should have specified. I'll get to troubleshooting this weekend.
  6. Oct 12, 2018 at 5:44 PM
    LoriB01
    LoriB01 [OP] Member
    Lori
    Atlanta
    If I'm reading this correctly the Red with White wire should be hot. I borrowed a multimeter from a neighbor and checked the wires at the switch. They all show ground with little resistance (assuming I'm using the tool correctly). The red with white stripe goes hard to the right on the meter (analog). So, to be clear, I can't get the meter to read 0 on the ohms scale, it stops at 3.5 when I've got the probes touching. Most of the wires that show anything are between 3.5 and 4 on the ohm meter, the red/white wire pegs to 0.
    So would I be correcting in looking for a short on that wire?
    It seems wrong to me that the relay would sound like it's working if that wire was shorted.
  7. Oct 12, 2018 at 7:00 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    Dont ask me LOL! Keep bumping...
