Headlight Sealing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Martinmann21, Feb 8, 2019.
  1. Feb 8, 2019 at 7:32 AM
    Martinmann21
    Martinmann21 [OP] Member
    09 TRD off road
    So I am going to purchase some new headlights soon. MY DTRL have cracked my factory ones as well as a set I bought a couple of years ago. Annoying and after doing research I'm either going to do the DTRL mod/switch or just at least temporarily snip the wire that runs them and secure it so they don't turn on when my truck is cranked. Afterwards I am going to buy some 3m window ribbon to go around the edge to seal them to prevent the other problem I had which was condensation/fog. With that being said, what about the area around where the detachable blinker bulb is that you twist to get out and replace (the same thing that's been cracking my DTRL)? Do I need to put something there to prevent moisture/fog?
  2. Feb 8, 2019 at 7:37 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Martinmann21[OP] likes this.
  3. Feb 8, 2019 at 7:37 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  4. Feb 8, 2019 at 7:50 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    Op, post some pics of the cracking area(s).
    The seal on the bulb socket should be fine unless its brittle/cracked from the heat and there is a moisture source in the engine compartment. Most light assemblies are compromised around the edges where the clear lens meets the back of the light housing, usually due to insufficent sealing material. Rain and other moisture are being driven into the weak areas while driving and during extreme weather changes.
    Taco2Me likes this.
  5. Feb 8, 2019 at 7:56 AM
    Martinmann21
    09 TRD off road
    I will post pics in around an hour. I can't get to my truck before then. Thank you for your response. I have noticed that most if not all of the moisture came from where the headlight is and not really as much as the parking lights/blinkers are. The orange lens or whatever it's called is just cracked in half. Again, I will post pics in a while.
  6. Feb 8, 2019 at 7:59 AM
    hyper15125
    NJ (609)
    :thumbsup:
  7. Feb 8, 2019 at 8:39 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Leave the bulb in but cut the wire. Dont leave the hole empty.
    Use silicone to seal the new headlights.
  8. Feb 8, 2019 at 8:44 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Toyota released an update headlight for 05-11 trucks that solves this issue, often referred to as the TSB lights. The original units had a design flaw. Toyota also did a large free replacement program to those affected. The program ended a couple years ago though. However you can still purchase the updated OEM TSB lights. Below is the info copy/pasted from my headlight thread on the TRD smoked chrome versions. These will be the highest quality and best performing assemblies you can buy without doing a retrofit.
    OEM 2005-2011 smoked headlights:
    These are like the Pro lights, but came on select Sport models. These are available loaded with bulbs, and unloaded w/o bulbs, saving $60 off the set . These part numbers are for the unloaded housings. These are the updated TSB version of the lights that do not have the melting DRL issue.
    Right #81130-04173
    Left #81170-04173
  9. Feb 8, 2019 at 8:58 AM
    Martinmann21
    09 TRD off road
    So with these you're saying 1. I don't need to do the Mod on the daytime running lights to cut them off? 2. That I also don't need to do the special sealant around where the front and back pieces meet to prevent weathering inside??
  10. Feb 8, 2019 at 9:13 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    If you get the new TSB headlight housings, you should be good to go.
  11. Feb 8, 2019 at 9:15 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I didn't read all of the posts but I thought there was a recall/directive that allowed for 'free' replacement of the housings.
  12. Feb 8, 2019 at 9:16 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Correct. It is OEM, they solved the DRL issue, you don’t need to worry about trying to seal it to prevent leaks or condensation and it will have good UV protection so you don’t have to worry about fogging/hazing and it will have the best optical performance. On top of that they are the ‘Pro style’ darker chrome lights to look more aggressive.
    Here is a comparison to stock chrome vs smoked chrome in the 2012-15 light, so you can see the difference.
    Another compare pic
  13. Feb 8, 2019 at 9:17 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It’s expired.
  14. Feb 8, 2019 at 9:20 AM
    Too Stroked
    Tom
    There was, but it was for a limited time only - which unfortunately has expired.
    HBMurphy[QUOTED] likes this.
  15. Feb 8, 2019 at 9:23 AM
    HBMurphy
    Paul
    So California Coast
    None
    I have gone through a couple of sets of headlight housings. My latest pair (after my '12 conversion) was a set of COPA compliant and they have been great! The cheaper Chinese ones suck.
  16. Feb 8, 2019 at 9:38 AM
    Martinmann21
    09 TRD off road
    Awesome, love these!! Thanks for all your help this saves me a lot of time.
    crashnburn80[QUOTED] likes this.
  17. Feb 8, 2019 at 9:43 AM
    Martinmann21
    09 TRD off road
    Newfiebruh likes this.
  18. Feb 8, 2019 at 9:47 AM
    hyper15125
    NJ (609)
    I honestly wouldnt even bother trying to fix those.
  19. Feb 8, 2019 at 9:48 AM
    Martinmann21
    09 TRD off road
    Yea, I figured so, just wanted to be able to purchase new ones without this happening to me again. Really pisses me off
    nirav2011 and crashnburn80 like this.
  20. Feb 8, 2019 at 12:14 PM
    Too Stroked
    Tom
    Truth be told, that happens fairly rarely on OEM headlight housings. And the biggest reason I've seen for it happening on OEM housings is folks not seating bulbs properly / fully. Now for aftermarket housings, it's a whole different story. I've seen so many of them leak I've lost count. Everybody talks about adding sealants to them and I ask why the hell one should need to add anything if the housings were properly designed and built in the first place - which of course most of them are not.
    On the bright side, there are usually used OEM housings available for relatively cheap from folks who slap the aftermarket junk in their trucks. Snag a pair before somebody figures out they're useless.
