Headlight lens replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheDuke0fHurl, Oct 8, 2014.
  1. Oct 8, 2014 at 6:51 PM
    TheDuke0fHurl
    TheDuke0fHurl [OP] Well-Known Member
    Boston
    2013 DCLB SR5
    Can I replace just the lens or do I have to replace the whole assembly?? My buddy had bad cables which melted the lens when I jumped him. And yes everything was hooked up right.
  2. Oct 8, 2014 at 6:52 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Sucks.
    Thanks,
    Brett
  3. Oct 8, 2014 at 7:08 PM
    TheDuke0fHurl
    Boston
    2013 DCLB SR5
  4. Oct 8, 2014 at 10:16 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You have to replace the entire housing assembly.
  5. Oct 8, 2014 at 10:24 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    unfortunately this is true
  6. Nov 13, 2017 at 6:44 PM
    RandySavage
    RandySavage Well-Known Member
    Rob
    Cape Breton Island, Canada
    2010 Tacoma TRD OR MT
    Never Satisfied
    I think its bullshit that no one sells just the lens, you could easily heat up the assembly and replace the lens yourself
    goldenhound and Manfred like this.
  7. Nov 14, 2017 at 8:56 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    After you snap into a SlimJim, anything is possible...
    Yurizx6r, blu92in99 and abqnurse80 like this.
  8. Nov 14, 2017 at 9:10 AM
    OKTACO
    OKTACO Well-Known Member
    Ty
    2005 SR5 Taco
    There are so many issues with condensation inside the lens on aftermarket headlamps that wouldnt make much sense to make them.
  9. Nov 15, 2017 at 5:02 AM
    RandySavage
    Rob
    Never Satisfied
    its easy enough to put it next to a dehumidifier and seal it properly
  10. Nov 15, 2017 at 12:01 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Have to replace the whole assembly.
  11. Nov 15, 2017 at 3:52 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    X2, but beware. There are many, many aftermarket headlight housings out there. Some look just like the OEM housings. Generally speaking though, you get what you pay for and many of the aftermarket housings end up looking like an aquarium in pretty short order. Oh, and the light pattern some of them put out is pretty pathetic too. Like I said, beware.
    PackCon[QUOTED] and crashnburn80 like this.
  12. Nov 15, 2017 at 4:30 PM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    I wonder if an inexpensive aftermarket headlight lens will match up with a stock housing?
  13. Nov 16, 2017 at 4:51 AM
    RandySavage
    Rob
    Never Satisfied
    boys are right there is no OEM or aftermarket lenses
  14. Nov 16, 2017 at 8:29 PM
    L J
    Illinois
    I know that there aren't any vendors selling just lenses. What I'm talking about is buying a pair of aftermarket headlights for cheap, heating them up in the oven and seperating the lenses then combining the aftermarket lenses with stock housings. If this is possible you could have clear lenses with OEM housings/reflectors for a fraction of the cost of new OEM headlights.
    RickTRDSport likes this.
  15. Nov 16, 2017 at 9:35 PM
    Pigpen
    Northwest Montana
    Go to a junkyard. Pull the light (s) off of a Tacoma. BAM. You got lights
