Headlight condensation even after sealing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Justyn98, Nov 7, 2017.
  1. Nov 7, 2017 at 3:41 PM
    Justyn98
    Justyn98 [OP] Well-Known Member
    Justyn
    West Virginia and Kentucky
    09 barcelona red tacoma trd sport DCSB
    Led pod fog light inserts, kn cold air intake, Bilstein 5100 with 2 inch coil combo and progressive AAL. Touchscreen pioneer stereo and infinity components with 2 kicker comp r10's and jones turbine exhaust
    Hey yall I recently got some aftermarket headlights, I went and bought GE silicone and went around the seals thoroughly. I even put on 2 coats of it, ive been reading and saw several posts that said to drill a small hole in the bottom of the headlights with a very small bit. this is the second time ive had this problem with aftermarket and I'm running out of options....I really don't want to take the headlight out again.
  2. Nov 7, 2017 at 3:43 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Leak at the dust boot?
    If you’re double sealed at the seams, I’d stop checking them as leak areas.
  3. Nov 7, 2017 at 3:45 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Agree with James, I downgraded to set of LED Bulbs and had to tear the dust boot just a bit. 2 days later condensation in the Headlamps. To the garbage out bought new dust boots and gone
    crashnburn80 likes this.
  4. Nov 7, 2017 at 3:48 PM
    Michael_Westen
    Michael_Westen Well-Known Member
    NC
    2018 Tacoma Double Cab TRD Off Road Inferno
    What brand headlight assemblies did you use?
  5. Nov 7, 2017 at 3:48 PM
    Justyn98
    Justyn
    the condensation looks to be at the bottom, I checked the dust boots as well theyre on perfectly, the only thing ive seen online to do is to either take them apart...which is a no go, or drill a small hole at the bottom to act as a vent hole. considering most headlight have vents on the back. these do not
  6. Nov 7, 2017 at 3:50 PM
    Justyn98
    Justyn
    Spyder
  7. Nov 7, 2017 at 3:56 PM
    T4RFTMFW
    When is condensation not at the bottom? Water heavier than air.
    You can try a hole, I guess. I don’t think it’s as perfectly sealed as you think (obviously). My guess is the dust boot directly or indirectly (it isn’t sealing properly due to bulb choice or design).
    ChemDawg likes this.
  8. Nov 7, 2017 at 3:57 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    Damn I found some by Spyder that I wanted to try out, but keep seeing things like this.
  9. Nov 7, 2017 at 3:59 PM
    reefnfeef
    reefnfeef Well-Known Member
    Bridger, MT
    '14 Pyrite Mica DCLB TRD Sport
  10. Nov 7, 2017 at 3:59 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I would honestly pay the extra money for some lights from a reputable builder. Stay away from these Fleabay or Amazon junk sets.
  11. Nov 7, 2017 at 3:59 PM
    Justyn98
    Justyn
    they weren't fogged up until I drove down the road with the headlights on, my guess is my hid heated up the inside of the headlight and there was no where for the cold air to escape so it created condensation, I'm no scientist tho lol
  12. Nov 7, 2017 at 3:59 PM
    T4RFTMFW
    DEPO is by far the more credible option.
    Neither are OEM tight though.
    TacoCat and Unchained 5150 like this.
  13. Nov 7, 2017 at 3:59 PM
    Justyn98
    Justyn
  14. Nov 7, 2017 at 4:00 PM
    reefnfeef
    Bridger, MT
    Not sure. You could also try some sort of desiccant pouches
  15. Nov 7, 2017 at 4:01 PM
    T4RFTMFW
    They’d still fog. Those absorb moisture, not remove it.
  16. Nov 7, 2017 at 4:02 PM
    Justyn98
    Justyn
    the main question is, would drilling a tiny hole to act as a vent help? if it makes it worst I can always reseal the hole itself especially if I make it small enough that water/rain cannot enter but moisture can escape?
  17. Nov 7, 2017 at 4:03 PM
    reefnfeef
    Bridger, MT
    if moisture can enter, water and rain can too.
  18. Nov 7, 2017 at 4:06 PM
    Justyn98
    Justyn
  19. Nov 7, 2017 at 4:10 PM
    T4RFTMFW
  20. Nov 7, 2017 at 4:12 PM
    Justyn98
    Justyn
    I just cant understand how they fog even with the factory sealant plus 2 coats of silicone, and the dust boots are on securely, what sucks is like I said this is my second set that has fogged up
