Headlight alignment ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KJaikaran, Apr 1, 2013.
  1. Apr 1, 2013 at 10:26 PM
    KJaikaran
    KJaikaran [OP] Well-Known Member
    Orlando FL
    2011 Tacoma DCSB TRD Sport
    URD intake/maf calibrator, Icon extended travel coilovers, Icon UCA, OME Dakar leaf packs, Bilstein extended rear shocks, 3 degree axle shims, Carrier bearing drop bracket, DS2 retro, 5k HID bulds top and bottom
    I was driving behind a friend and he mentioned to me that it seemed like i had my bright lights on. I have noticed when i'm behind people while driving the light cutoff is kind of high and i would assume from the their point of view it must seem like i have my high beams on.
    DS2 projectors and 3" lift
    Does anyone know if there is a specific height your headlight cut off is supposed to be at ?
    From the research i have found to align the headlight vertically you have to be on a flat surface and 25 feet away from the wall, or what ever your using to determine your cut off line, and your cut off line should be 2" lower than your actual bulb/projector output that shows up on wall (most concentrated part of light hitting the wall). So if you measure from the headlight (most centered part of projector, or bulb) to the ground your cut off line should be 2" lower than that measurement. Halogen bulbs should be at the same measurements. As far as ground to cutoff height i have no idea if their is a number i should be adjusting too so i can compensate for the lift. Is it as simple as adjusting the headlight 3" down from where its supposed to be for compensating the lift ? I wonder if it will even adjust that much down.
    Update:
    Found a resourceful video provided by Ford :eek:.
    http://www.youtube.com/watch?v=t16PaSm9Nb4
    Also found some very good information on a Subaru forum.
    http://legacygt.com/forums/showthre...ights-if-you-dont-know-now-you-do-54740.html?
    Any input would be appreciated.
  2. Apr 1, 2013 at 10:53 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Park an average car infront of you, as if you were pulled up behind them at a light. Then aim the lights to just below their side mirrors, and you should be good.
    When you start adding lifts, it becomes more of a guessing game than a measuring one.
  3. Apr 2, 2013 at 4:01 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    . x2 on the guessing game with lifts but I would try to crank it down 2-3" inches. Remember you will have to do the fog lights too.
  4. Apr 2, 2013 at 5:13 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Lifted or not, aiming your headlights is not a guessing game. There is a set procedure on how to properly aim your headlights. Unless you're running over 3" of lift, there's no reason to not use the standard procedure, if you're over that then you might have to start messing with your lights so you can still see but you aren't blinding everyone.
  5. Apr 2, 2013 at 10:43 AM
    KJaikaran
    Orlando FL
    Good idea, but i am kind of worried about it being an accurate alignment too stock.
    Yah, i was thinking about just aiming down about 2-2.5" from cut off line to compensate.
    I actually used the same procedure, but that factory procedure is with the tacoma at stock height. I would assume just subtracting the lift from the cutoff line would work, but i guess there is only one way to find out. If i could get a measurement with a non lifted tacoma 25 feet away with a measurement from ground too cut of line that would be perfect.
  6. Apr 2, 2013 at 10:48 AM
    KJaikaran
    Orlando FL
    I always thought there was a specific height the cut off is supposed to be at for every vehicle. I mean, i have gotten tickets in previous cars lowered where the cop said my headlights are too low, you would figure what difference it would make if the cut off is adjusted to the right height, but they don't see it that way.
  7. Apr 2, 2013 at 10:55 AM
    hakabo
    hakabo Well-Known Member
    Jacob
    Concord, NC
    08 urban runner 4x4
    Sub'd
  8. Apr 2, 2013 at 11:06 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    It's pretty cool when your lights are aimed high and lights up the whole interior of the car in front of you. I never bothered to aim my lights down after the lift.
  9. Apr 2, 2013 at 11:07 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Gotta see the squirrels in the trees.:rolleyes:
    Most shops have a level or other tool that they can adjust your lights with, No excuse to have them aimed bad.
  10. Apr 2, 2013 at 1:40 PM
    KJaikaran
    Orlando FL
    Updated 1st post
    guess i will just follow the procedure in aligning the headlights and angle them down to compensate the lift.
  11. Apr 2, 2013 at 1:49 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I did this with my lights a couple weeks ago. I used the shorter distance from the wall than the 25'. It's in the instructions, I thinks it's 9' or something. I used a piece of drywall laid up against back wall of my garage. The needed adjusted down about 6".
  12. Apr 2, 2013 at 2:00 PM
    KJaikaran
    Orlando FL
    6" seems like a lot. What size lift do you have ? I was thinking about adjusting them down 2-2 1/2" to compensate a 3" lift then just fine tuning it. Wish i would have thought of this in advance before lifting the truck so i could have gotten some stock height measurements of the headlights.
  13. Apr 2, 2013 at 4:28 PM
    KJaikaran
    Orlando FL
    Can anyone without a lift get me a measurement from the ground to the center of the bulb in the headlight for a 2nd gen 05-11? I would really appreciate it.
  14. Apr 2, 2013 at 4:31 PM
    moondeath
    Pa, Gardners
    Just use the numbers they give you here. You draw a grid out on a wall and align your lights accordingly. You don't really need to worry about your left to right. Just up and down. Oh, I'm only lifted 2.5" in the front. But they were way over the grid line and I was always getting people flashing their lights at me.
    http://www.tacomaworld.com/forum/attachments/2nd-gen-tacomas/204698d1364900463-headlight-alignment-foglight_adjustment-1-.pdf
