Headlamp assembly replacement/mod
Discussion in 'Lighting' started by rbeaver0308, Oct 26, 2018.
  1. Oct 26, 2018 at 2:17 PM
    rbeaver0308
    rbeaver0308 [OP] Member
    Richard
    Braselton, Ga
    2010 Tacoma Prerunner V6
    Ive got a 2010 Prerunner that needs a facelift. 1st thing on the list will be to replace to old, brown, melted headlamp assemblies with clear ones. The ones on Amazon get 2-3 out of 5 stars due to issues with leaking. 1- If I get these what can I do to prevent these from leaking? 2- can anyone recommend some place else?
  2. Oct 26, 2018 at 7:02 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Many aftermarket headlights end up leaking, and few have good optics meaning they do not perform as well as stock. I'd recommend these:
    OEM 2005-2011 smoked headlights:
    These are like the Pro lights, but came on select Sport models. These are available loaded with bulbs, and unloaded w/o bulbs, saving $60 off the set . These part numbers are for the unloaded housings. These are the updated TSB version of the lights that do not have the melting DRL issue.
    Right #81130-04173
    Left #81170-04173
    Color comparison from 2012-2015 style lights. Stock light on left, Pro on right:
  3. Oct 26, 2018 at 10:24 PM
    rbeaver0308
    Richard
    Braselton, Ga
    Thanks, I'll give them a look.
