Headache Rack & Tonneau Combo Options? (Mounting headache rack on top of bed rails?)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by j.d.mason, Nov 12, 2019.
  1. Nov 12, 2019 at 8:05 AM
    j.d.mason
    j.d.mason [OP] Well-Known Member
    Toronto, Canada
    2014 White TRD Sport DCLB
    Hey all,
    Does anybody have any options for mounting a headache rack while simultaneously having a tonneau cover installed in our trucks? I am looking at a couple different low-profile tonneau options (ideally roll-up), which need to be mounted within the rail system of our taco beds. As a result, my current headache rack (Back Rack), which also uses the bed rails, is not compatible.
    The only adapter brackets that Back Rack makes work with tri-fold tonneau covers that don't open up all the way (e.g. Extang Solid Fold 2.0). These brackets still use the factory bed rail system. (reference: Back Rack adapter brackets)
    I was wondering if anybody has mounted their headache racks to the top of the bed rails (i.e. through the plastic cap and into the side of the beds) which would allow the tonneau covers to be mounted within the bed rails without any conflicts. Any suggestions? Any examples? I am not necessarily opposed to drilling into the side of my bed, but wanted to know if there would be any problems/difficulties associated with doing something like that.
    Much thanks!
  2. Nov 19, 2019 at 1:32 PM
    j.d.mason
    Toronto, Canada
    Just politely bumping this back up - any insights/feedback/direction would be greatly appreciated!!!
  3. Nov 19, 2019 at 4:07 PM
    DaveSDao
    DaveSDao New Member
    Dave
    2018 white Tacoma TRD
    Hi John,
    See attached images
    WhiteBuddha likes this.
  4. Mar 22, 2021 at 4:31 PM
    Connorbu20
    Connorbu20 Member
    Connor
    Logan, Utah
    Do you have an explanation of what is being looked at in the top two pictures? I really like that setup and am considering go with something very similar to this.
  5. Mar 22, 2021 at 4:41 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers and a skewp
    He was showing the plate washer to reinforce the mounting location. If it's not fully supported it could fail.
  6. Mar 22, 2021 at 4:52 PM
    Connorbu20
    Connorbu20 Member
    Connor
    Logan, Utah
    That makes sense. How would you access the underside of the bed rail to mount the plate? Do you have to take the fender off or is there an easier access point?
  7. Mar 22, 2021 at 6:15 PM
    AllTacosFloat
    Boston ish
    Honestly never looked to attach anything there. I would think from there under side with long arms. Really not sure as I have not done it
