Head unit mutes, can’t figure this out.
Discussion in 'Audio & Video' started by anthony250f, Sep 5, 2020.
  1. Sep 5, 2020 at 11:18 PM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Been having an issue with my head unit muting completely. Only way to fix it is to unplug and plug back in this connector.
    my truck has JBL, but I wired all 4 speakers to the head unit directly. What would cause this issue? I replaced the head unit with the same one too to rule out that.
    915F68A0-C312-47C3-B9B7-399FDA1CA26C.jpg D6681B23-DF28-45AD-9859-FDE61AEF56A0.jpg
  2. Sep 5, 2020 at 11:19 PM
    anthony250f
    Anthony
    San Diego, CA
    The stereo system worked fine for a few years, it would rarely mute, but would be fixed if I turned it off and back on, but now the ONLY fix is to unplug and re-plug the connector back in.
  3. Sep 6, 2020 at 3:30 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Perhaps a speaker impedance mismatch?
    The JBL speakers had an amp between them and the head unit. Without that amp, maybe your head unit is shutting down to protect its internal amp from burning up from using 2Ω speakers.
    Edit: According to the manual, your head unit requires 4-8Ω speakers, whereas the JBL speakers appear to be 2Ω.
    Larzzzz and Philrab like this.
  4. Sep 6, 2020 at 10:04 AM
    anthony250f
    Anthony
    San Diego, CA
    Forgot to add it has aftermarket speakers. Kenwood I believe. They sound like crap though and the tweeters are garbage so I plan on replacing it all, and all 4 speakers are wired straight to HU to bypass JBL
  5. Sep 6, 2020 at 10:13 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Typically this is due to a short somewhere. If the head unit senses a short, it will turn off the internal amp to prevent it from damaging itself. If it only does it occasionally, it could be a loose connection on one of the speakers, or the speaker mounted too close to the sheet metal where the little braided wires on the underside are making contact with the door. That’s what I saw the most when I was doing installs.
    dolbytone likes this.
  6. Sep 6, 2020 at 8:07 PM
    anthony250f
    Anthony
    San Diego, CA
    Usual unplugging the connector and plugging it back in works, however today I tried that and it still doesn’t work, tried plugging I nx the jbl amp and still nothing
  7. Sep 6, 2020 at 8:48 PM
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    Not to sound like a jerk, but unless you have a multimeter and a bare minimum of electrical knowledge, you’re better off taking it to a shop.
  8. Sep 6, 2020 at 9:26 PM
    anthony250f
    Anthony
    San Diego, CA
    I do but figured someone might have some ideas before I pull off my door skins, and the jbl system doesn’t have too much information available on the web.
    Philrab[QUOTED] likes this.
  9. Sep 6, 2020 at 10:46 PM
    Philrab
    Phil
    Pop your head unit out. Check the following.
    1. Visually inspect wiring for kinks, breaks, bare wires, burnt insulation.
    2. Pull harness from head unit, check resistance on each pair of speaker wires (positive and negative for each channel). You’re looking for about 4 ohms, maybe a bit more or less. If you see substantially less you may have a short on that channel.
    3. Verify you have 12+ constant and 12+ ignition in the harness.
    4. Check ground circuit in harness for resistance.
    If none of the above yields some sort of direction I would suspect a defective head unit. If you trip across anything in the above checks we can follow up on that route.
  10. Sep 7, 2020 at 2:34 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    Just for fun, ground your head unit somewhere on the frame instead of through the harness next time you pull it out.
    My stereo reboots on occasion after returning the ground to the harness on a replacement. The previous stereo ran without incident for 10 years and I had that ground run back to the battery from chasing down some noise in the system.
    IMO the factory harness ground is kinda shitty and maybe that’s a factor.
  11. Sep 8, 2020 at 8:49 AM
    anthony250f
    Anthony
    San Diego, CA
    while im in the door panel i am going to upgrade the speakers. what do you think about doing 6.5 coaxials on all 4 doors and doing a kicker 3.5" midrange in place of the stock tweeter?
  12. Sep 8, 2020 at 8:52 AM
    anthony250f
    Anthony
    San Diego, CA
    heres the distaster the PO did and the reason why i ran new wire from all 4 speakers to the head unit lol
  13. Sep 8, 2020 at 8:58 AM
    destin_meeks
    Destin
    Tuscaloosa, AL
    Whoever did that work needs to be arrested.
    completely garbage work aside, WHY DO PEOPLE CUT WIRES SO CLOSE TO THE CONNECTORS?!?!?!?! There is zero way to easily salvage that amp connection at this point.
  14. Sep 8, 2020 at 9:01 AM
    anthony250f
    Anthony
    San Diego, CA
    the amp is long gone. i bypassed that and ran all door speakers directly to a new JVC head unit. removed the amp and all the other garbage that was jammed behind the back seat.
    just trying to figure out what speakers to go with on a budget
  15. Sep 8, 2020 at 2:19 PM
    Philrab
    Phil
    Personally, I wouldn’t do coaxial 6.5’s and a midrange where the tweeter is. Either put in components in the front doors, or do coaxial and bypass the tweeter in the stock location altogether.
    I did the former with Infinity Reference series. They aren’t what most would call cheap but I know what my ear likes and I’ve run them in my last three systems.
  16. Sep 8, 2020 at 4:37 PM
    anthony250f
    Anthony
    San Diego, CA
    I pulled off the door skins today and the rear speakers were a cheap “xprite” 3 way coaxial. I can’t really even hear the rear speakers but I might change them out with these cheAp JVC’s
    what do you think about this setup for a decent sound?
    trying to keep it between 100-130 total lol
  17. Sep 8, 2020 at 5:16 PM
    Philrab
    Phil
    No experience, but if you’re on that tight a budget I say upgrade the front speakers, skip the rear for now. Cheap speakers usually sound....cheap.
  18. Sep 16, 2020 at 8:32 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    That’s going to probably sound worse I would think. It’s a pretty cheap speaker plus it’s going to be underpowered.
  19. Sep 16, 2020 at 10:44 AM
    anthony250f
    Anthony
    San Diego, CA
    I ended up getting the skar fsx65’s up front with Rockford Fosgate tweeters and it sounds much better than what was there before.
    Also have not had any muting issues so far
    Philrab likes this.
  20. Sep 16, 2020 at 11:18 AM
    Philrab
    Phil
    Assume it was either a wiring issue or a short in the speaker then. Glad it’s fixed.
