Head & Brake lights working when key off?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toyotafan83, Apr 26, 2013.
  1. Apr 26, 2013 at 10:33 AM
    toyotafan83
    toyotafan83 [OP] Member
    Jon
    VA
    2012 V6 DCSB TRD OR
    Deezee Bull Bar
    I have a 2012 tacoma. Last night i noticed that my head and brake lights would work even though the key was out. I've never noticed the lights working when the key is out of the ignition. I know in some cars the headlights will turn on but not the brake lights too. Is this normal for these trucks? Does anyone else's lights work when the key is turned off?
  2. Apr 26, 2013 at 10:42 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    Must be 2012 maybe. Mine turn off when I pull the ignition key. Even when I leave them on.
  3. Apr 26, 2013 at 10:45 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I have never seen a vehicle that the running/headlights will not turn on when the key is out. I have an '02 and the headlights turn themselves off when I turn the ignition off but if I turn the headlight switch off and back on the lights will come on even with the key out
  4. Apr 26, 2013 at 10:49 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    My '06
    Drivers Door closed, headlights on, turn engine off, take key out - Headlights stay on until the Drivers door is opened.
    Drivers Door open, headlights on, turn engine off, take key out - Headlights turn off immediately.
    I have run into a time or two under different scenarios that I had to turn the headlights off manually, like if I turned the headlights on when the engine was off but the key was still on. When the key was taken out the lights stayed on.
  5. Apr 26, 2013 at 10:51 AM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    brake lights work a lot of times with the key out.
  6. Apr 26, 2013 at 2:42 PM
    BamaToy1997
    Bill
    Navarre, FL
    Perhaps the OP should clarify something. He didn't say they stayed on. He said "they work", which I took to mean that he can turn the headlights on and off without the key in the ignition, and when he presses the brake pedal, the brake lights will come on. This is normal of course, as pretty much every vehicle out there will have their brake lights come on when pressed, even if the key is out of the ignition, as well as the headlight switch will still turn on the headlights.
  7. Apr 26, 2013 at 4:52 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    2011 key off door closed lights on door open lights out.
  8. Apr 26, 2013 at 5:25 PM
    toyotafan83
    Jon
    VA
    2012 V6 DCSB TRD OR
    Deezee Bull Bar
    Yes Bamaboy i meant the head and brake light will turn on and off without the key, also the brake lights will light up without the key. I had an 06 tacoma for a few years and i've had my 12' for over a year and i've never noticed it until last night. What surprised me the most is that my brake lights will come on when the brake pedal is depressed.
  9. Apr 26, 2013 at 5:30 PM
    sirwillysc
    sirwillysc Well-Known Member
    Will
    Columbia SC
    13 Tacoma Dbl Cab TRD Off Road
    Debadged destickered
    YES very normal like every car in the world does it.
  10. Apr 26, 2013 at 5:40 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Yup.
    Perfectly normal.
    Turn signals will shut off with the key, but the hazards (normally powered from the brake circuit) and brake light will operate any time.
    Same for the parking lights and headlights.
  11. Apr 26, 2013 at 11:39 PM
    toyotafan83
    Jon
    VA
    2012 V6 DCSB TRD OR
    Deezee Bull Bar
    thanks for the info fellas
