Head bolt torque specs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by challis101, Nov 13, 2014.
  1. Nov 13, 2014 at 7:29 PM
    challis101
    challis101 [OP] New Member
    NJ
    toyota tacoma 2.4
    none
    What is the torque specs for head bolts on 96 Toyota Tacoma 4Cyl 2.4?
  2. Nov 14, 2014 at 11:16 AM
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    MGM 21 TRD OR 6sp MT
    Soon...
    It's a three step process.
    Step one: torque bolts to 29 ft/lbs
    Step two: tighten bolts an additional 90*
    Step three: tighten bolts an additional 90*58a472583737c7cb4f4339b1bca7ee61_f06200babb7fbf7939f7bc3ddf5114884e118cf6.jpg
    KalamaKid and Dalandser like this.
  3. Jun 29, 2017 at 5:50 PM
    wildgoose2005
    wildgoose2005 Well-Known Member
    Nick
    Gen 1 taco.
    About to do this myself, so step 1 is 29#,s step 2 is 90#s and step 3 is go back over with 90#s again?
  4. Jun 29, 2017 at 5:51 PM
    wildgoose2005
    Nick
    Gen 1 taco.
    Never mind, Mia understand. 1/4 turns at 29#s
    Dalandser likes this.
  5. Jun 29, 2017 at 7:03 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    After they are all at 29 ft-lbs, you turn them each 90° with a regular wrench in the order shown, then another 90° with a regular wrench in the order shown. Put a paint mark on the top of the bolts so you can verify that you turn each the correct amount. You don't want to have the wrench slip or something and not know how many degrees they were turned.
    Also clean the holes out with compressed air, be sure the bolts thread in nicely before you place the head on the block. Coat the threads with a light coat of engine oil and a light coat on the head bolt washers. The torque value of 29 ft-lbs is based on this.
  6. Aug 30, 2018 at 7:56 AM
    Newbie62
    Newbie62 Member
    Rusty
    1999 Toyota Tacoma Prerunner
    What about the two front bolts?
  7. Aug 30, 2018 at 10:37 AM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    After tightening the the main head bolts, for the 2 bolts in front if the timing gear the 96 repair manual says:
    (g) Install and torque the 2 bolts.
    Torque: 21 N·m (210 kgf·cm, 15 ft·lbf)
    I'll mention that there are 2 locations where sealant should be applied under the head gasket on the head just behind the timing gear. You'll have to download the repair manual or find a diagram or thread where someone shows that.
