Hayden Transmission Oil Cooler Install
Discussion in '1st Gen. Tacomas (1995-2004)' started by zero4, Aug 16, 2010.
  1. Apr 11, 2014 at 11:15 AM
    #121
    stikle
    stikle Well-Known Member
    Seth
    The Sovereign State of Eastern Oregon
    1997 LX Xtracab 4x4 V6 3.4L
    Eh, see my Build Thread sig link. Too many mods to list.
    Wish I would have had that piece of advise when I did mine...would have made for a cleaner install.
  2. Apr 11, 2014 at 6:32 PM
    #122
    asus611
    asus611 Well-Known Member
    CA
    03 Double Cab Prerunner
    Look at bottom of your radiator. The bottom of the radiator is where the tranny fluid is "cooled" from the trucks radiator. The driver's side is the return side. I plumbed in my Hayden using a hose from the driver side radiator into the inlet side of my Hayden cooler.
    Basically, the inlet hose on your Aux tranny cooler should be connected to the driver's side radiator exit hole.
  3. Apr 27, 2014 at 10:05 AM
    #123
    03DoubleCab94
    03DoubleCab94 Member
    Grant
    Scottsboro, Alabama
    03 double cab 2.5"
    2.5" rough country lift kit, 32" toyo open country mt's, cb radio, camper shell, inno roof rack cross bars, vantech camper shell cross bars with roof rack
    Where do the lines connect to from the oil cooler to the radiator? I want to do this mod but can't risk messing up my truck by cutting into the lines. Can I get a walk through?
  4. Sep 26, 2016 at 6:46 AM
    #124
    chilioil.514
    chilioil.514 Well-Known Member
    2003 Tacoma TRD Prerunner 4-Door
    Prodigy P2, Alpine 235BT, Hayden Aux Trans Cooler, Scan Gauge II
    Excellent thread and thanks for the details. I was able to install a Hayden cooler myself and then had the oil lines installed at a local shop.
    frenchee likes this.
  5. Sep 26, 2016 at 5:12 PM
    #125
    chilioil.514
    Forgot to mention that I got the aluminum bracket from Home Depot. Also broke the clips to the corner lenses while removing. Packaging tape worked well temporarily to hold in place and wasn't an eye sore. Luckily, Amazon had replacement lenses for much less than the dealership.
  6. Oct 11, 2016 at 4:32 PM
    #126
    mrschulte
    mrschulte Well-Known Member
    Indiana
    95 v6 Ext Cab Tacoma Dlx
    I'm getting ready to replace my radiator and while I'm at it I am going to install a cooler. Did any of you install an inline filter while you were at it?
  7. Oct 14, 2016 at 6:36 PM
    #127
    theox26
    theox26 Well-Known Member
    '11 DCLB Sport
    I've been doing research to replace the trans cooler for towing since the TRD one is worthless. I do plan to add an in-line filter like the magnefine.
    One other important thing from this thread, there seem to be a lot of posts saying to install the lines backwards. The in should be at the bottom with the out at the top or both at the top. Don't ever install it with both lines at the bottom. My cooler has instructions stating this and it is because of how the fluid would not flow through the cooler if it isn't forced to so it would do very little to help cool anything.
  8. Jan 10, 2017 at 7:22 PM
    #128
    rarbage
    rarbage Member
    2013 all about that base
    does anyone know if the diagram option 1 earlier in this thread is applicable for 2nd gen ?
  9. Feb 10, 2017 at 5:46 PM
    #129
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
  10. Feb 10, 2017 at 5:48 PM
    #130
    Misplaced Nebraskan
    Zach
    Austin
    Oops. Wrong thread... Still fits though free bump
  11. Feb 10, 2017 at 9:14 PM
    #131
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Lol when we used to have green bars as rep.
  12. Feb 10, 2017 at 9:20 PM
    #132
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    This is the waaaaaay baaaack machine......
  13. Jun 2, 2017 at 12:49 PM
    #133
    Pinchet4co
    Pinchet4co Active Member
    Jesse
    Studio City, CA
    2001 Black Taco Prerunner 4 cyl
    Stock...for now!
    Great job! I got mine in a couple of weeks ago and this post is going to be really useful.
  14. Oct 5, 2017 at 5:50 PM
    #134
    tony2018
    tony2018 Well-Known Member
    Just dug this up and yes I know its old but this is exactly what I need to see and i wanted to say nice work and I wish I had a lathe. Thanks OP.!!
  15. Oct 6, 2017 at 7:36 AM
    #135
    Timmah!
    Timmah! Well-Known Member
    TIM
    Here's a video I made installing an external trans cooler on my 3rd Gen 4runner.
    <iframe width="560" height="315" src="https://www.youtube.com/embed/2nVbwe2t2T8" frameborder="0" allowfullscreen></iframe>
    frenchee and lucky13don like this.
  16. Oct 6, 2017 at 7:40 AM
    #136
    tony2018
    Thanks for the video Tim. But the reason why I'm not going the route of ziptie is because I'll be working on replacing the ac system next. Its not as cold and the bearing on the compressor is done. PO drove through flooded roads or something because there's alot of rust spots I need to hit up.
  17. Oct 6, 2017 at 7:51 AM
    #137
    Timmah!
    TIM
    Roger that. Since you'll be working on your AC system, check out this video my buddy Sean and I made. I think you'll find it very informative.
    <iframe width="560" height="315" src="https://www.youtube.com/embed/zlRE0Zeeyrc" frameborder="0" allowfullscreen></iframe>
    tony2018[QUOTED] likes this.
  18. Oct 6, 2017 at 7:55 AM
    #138
    tony2018
    Awesome thanks! and liked both TW and on yt.
    Timmah! likes this.
  19. Jul 3, 2018 at 3:49 AM
    #139
    tcub
    tcub Member
    Tim
    Cocoa Beach
    '04 Taco V6 TRD Xcab
    I know this is old thread but it's exactly what I am looking for. Installing same cooler on my 04 Taco. Great pics, thanks!
    zero4[QUOTED][OP] likes this.
  20. Jul 3, 2018 at 7:31 AM
    #140
    zero4
    zero4 [OP] Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    :thumbsup:
