Hayden Transmission Oil Cooler Install
Discussion in '1st Gen. Tacomas (1995-2004)' started by zero4, Aug 16, 2010.
  1. Jun 27, 2013 at 6:08 PM
    #81
    cr500taco
    cr500taco Well-Known Member
    D
    Northridge
    4WD
    All right, thanks.
  2. Jun 27, 2013 at 9:12 PM
    #82
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I have the 679 in mine. I'm also running through the radiator trans cooler as well.
    I do think its overkill and should probably go with the 678.
    As far as cooling though, my trans temp never gets higher than my engine temp.
    I was just in Moab a few weekends ago and my engine did get up to 210s. Trans up to 200s. Outside temps were close to 100. I experimented with and without AC and it didn't seem to make much difference. Its really the long steady uphill grades that will heat up both the trans and the engine pretty good, which is where I saw the highest temps.
    Anyway, I dont believe I have any issues with not being able to cool enough. I think it is pretty close to borderline though, as for why I'd recommend going with something smaller than the 679.
  3. Jun 27, 2013 at 9:46 PM
    #83
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    How and where r u pulling ur trans temp?
  4. Jun 27, 2013 at 9:55 PM
    #84
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I rely on my scangauge and I'm guessing he does too. I would be curious to know where the stock sensor is.
  5. Jun 28, 2013 at 10:24 AM
    #85
    DIRT YOTA
    Cory
    Camarillo, CA
    Ya cuz I was told there isn't a port or sensor dealio in the trans on 1st gens..... Hmmmm I got an ultragauge I'm putting in at some point lol. Had for a year or two now.
  6. Jun 28, 2013 at 8:30 PM
    #86
    cr500taco
    D
    Northridge
    4WD
    Thanks for that info. I am going to be stopping by my tranny shop to see what they suggest. I had my trans rebuilt about a year ago and I trust the guy.
  7. Jun 28, 2013 at 9:51 PM
    #87
    DIRT YOTA
    Cory
    Camarillo, CA
    Ask him where and how the scan gauge or whatever pulls the trans temp...directly from trans, or from a line or what.....
    Unless someone can chime in with some info...
  8. Jun 29, 2013 at 2:22 PM
    #88
    cr500taco
    D
    Northridge
    4WD
    I talked with my tranny guy, today about the coolers. He said, get the biggest that I can. I told him what Hayden said about the cons of getting a bigger cooler than needed with the concerns of not enough air getting to the radiator and condenser and he said he's never seen a problem like that. Didn't get a chance to ask him about pulling the trans temp. He was busy and I didn't want to take up too much of his time.
  9. Jun 29, 2013 at 2:36 PM
    #89
    cottontop
    cottontop Active Member
    Alabama
    10 DCSB 4x4 TRD OR
    ARB Bumper 8000lb Warn
    Look at the tru cool brand of tranny coolers. I have a 6.0 swapped Chevy blazer with a 4l80 tranny and a 3k stall converter. I run a try cool 40k. They are big in the LS swap world . This cooler made a believer out of me. Even with the stall towing my boat tranny temps have never got over 165
  10. Jun 29, 2013 at 7:45 PM
    #90
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
    This, I recently installed a Tru Cool 4590 on my 02 T4R... I bypassed the radiator and have this as the sole source of cooling. In 90+ degree stop/go traffice my trans never gets above 150 according to my Scan gauge, it usually avgs 130-140 range. Yes, it may be excessive to some but I really like this cooler.
  11. Jun 30, 2013 at 7:40 AM
    #91
    cr500taco
    D
    Northridge
    4WD
  12. Jun 30, 2013 at 10:40 AM
    #92
    cr500taco
    D
    Northridge
    4WD
    El Rio,
    I PMed Will a few days ago with my question like you suggested and I haven't heard back, yet. He doesn't have a contact email on his profile.
  13. Jun 30, 2013 at 1:40 PM
    #93
    DIRT YOTA
    Cory
    Camarillo, CA
    I may have his number, if I do I'll text him to post.
  14. Jun 30, 2013 at 1:41 PM
    #94
    DIRT YOTA
    Cory
    Camarillo, CA
    Nope old phone, sorry man.
  15. Jun 30, 2013 at 8:47 PM
    #95
    cr500taco
    D
    Northridge
    4WD
    Thanks for checking.
  16. Jul 2, 2013 at 7:46 PM
    #96
    cr500taco
    D
    Northridge
    4WD
    I am going to be getting a Tru Cool LPD cooler. My next question is, stacked plate or plate and fin, which is better?
  17. Jul 3, 2013 at 4:53 PM
    #97
    AlphaEcho2k5
    Adam
    Hurlburt Field, FL
    '02 4Runner
    I hear stacked plate is the way to go.:cool:
  18. Jul 15, 2013 at 6:40 PM
    #98
    cr500taco
    D
    Northridge
    4WD
    Where did you mount your 4590? I am looking into the 4490 which is a little smaller. It's a little longer but 1/2 as thick. I have read where people say that the Hayden 679 is a tight fit and it's smaller than the 4490, but with my measurements it seems like the 4490 will fit.
  19. Aug 4, 2013 at 1:32 PM
    #99
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    A little upset with my Hayden. I did some spirited driving up GMR to go wheeling in Asuza- temps got near 220. I have tranny > Hayden (don't remember model, its frickin big) > OE cooler in radiator > tranny.
    Either Hayden isn't that good, or my tranny isn't flowing fluid like it should, or routing it back to the OE cooler (to ensure it doesn't get overcooled) is negating the hayden.
    I'm now debating--
    a) should I build some custom shrouding? The hayden probably isn't performing anywhere near it's potential, lots of air is probably going around it and not through it.
    b) change the plumbing to standalone- in that case I would probably want to change to a Long Tru-Cool because of my fear of overcooling
    c) B&M makes coolers with fans attached. I suppose that would put a big stop to overheating.
    I'm very surprised my cooler is performing so badly. Not even towing...
    Here is a pic for reference of size, plumbing and air flow. I'm thinking maybe some ducting/shrouding could make all of the difference.
    ** EDIT, just hunted down the TRD cooler instructions, TRD has you install the aftermarket cooler POST OE cooler. So maybe my fears of overcooling are not founded, and I should install the TRD route, possibly increase the performance of my setup...
  20. Aug 4, 2013 at 5:56 PM
    #100
    cr500taco
    D
    Northridge
    4WD
    I'm getting a TransCool LP cooler for mine. Had my tranny rebuilt over a year ago and that's the brand my tranny guy recommended.
