Having trouble finding a 40 amp fuse
Discussion in '1st Gen. Tacomas (1995-2004)' started by SinCityYeti, Oct 21, 2020.
  1. Oct 21, 2020 at 1:32 PM
    SinCityYeti
    SinCityYeti [OP] Active Member
    Gregg
    1998 Tacoma Ext Cab 4x4
    I am having trouble finding a 40 amp fuse to fit my 98 4x4 SR5. It's the AM1 fuse for the ignition. I went to O'Reillys and the The Dealer and the one they both have has grooves in the fuse body and fits into the location on fuse box, but not all the way. Where the contacts go into the fuse the slots are offset, whereas the original one is not offset.
    The one I got from Autozone has the correct alignment for the terminals, but the body of the fuse does not have grooves, so the fuse will not go all the way down into the correct spot in the fuse box. The old fuse is grey, but all the replacements are green and wont fit right.
  2. Oct 21, 2020 at 1:45 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Simple work around till you find the correct fuse .
    Install a inline fuse with the correct size wire and fuse holder
    whatstcp and SinCityYeti[OP] like this.
  3. Oct 21, 2020 at 1:58 PM
    SinCityYeti
    Gregg
    I have the fuse that wont seat all the way in there for now, but definitely want the right one and the right fit.
  4. Oct 21, 2020 at 2:00 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Junk yard?
    Have you checked NAPA?
    SinCityYeti[OP] likes this.
  5. Oct 21, 2020 at 2:05 PM
    SinCityYeti
    Gregg
    I'll check NAPA. Junkyard may be an option now that its not 100 degrees out.
  6. Oct 21, 2020 at 2:07 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    If you can't find one that has the appropriate Toyota, also look at Honda vehicles in the same age range.
  7. Oct 21, 2020 at 3:03 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    Try this part # from Toyota...90982-08284.
  8. Oct 23, 2020 at 11:36 AM
    SinCityYeti
    Gregg
    I was able to find the fuse at NAPA after the Toyota dealer told me they couldn't help me.
  9. Oct 23, 2020 at 12:02 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Not all Toyota Parts departments are so lazy.
    Mine would most often reply I will put the order in we will see what happens.
    Since not to many parts for 20 plus year old vehicles on the shelf
  10. Oct 23, 2020 at 12:15 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Grab a bunch of spare fuses whenever you are at a junkyard. You could probably find this fuse an most Toyota models from this era.
    Wulf likes this.
  11. Oct 24, 2020 at 8:39 AM
    homegrown_xt
    Sonoma County
    Hi, I was just looking into this fuse a little further.
    When you got the fuse from the dealer did you get a green fuse with a clear top and it said 40A? That is a medium current fuse and the part # is 90982-10002.
    The other part that I found is also green but the window where it says 40 has a bluish purple tint and the numbers are white, this is a fusible link, I think this is the one you are looking for. Part # is 90982-08284, I hope this helps you out.
    Keep us posted.
    DrZ likes this.
  12. Oct 26, 2020 at 9:48 AM
    SinCityYeti
    Gregg
    Not sure how the order of threads is supposed to work, but I posted earlier that I got lucky at NAPA.
  13. Oct 26, 2020 at 2:08 PM
    homegrown_xt
    Sonoma County
    I just wanted to see why the Toyota Dealer couldn't figure it out.
  14. Oct 26, 2020 at 3:17 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Not all parts counter people are created equal
    It took a few years to get my Toyota parts people up to speed.
    Thatbassguy likes this.
