Hauling sand
Discussion in '3rd Gen. Tacomas (2016-2023)' started by imagineer, Jun 15, 2021.
  1. Jun 15, 2021 at 6:02 AM
    imagineer
    imagineer [OP] Well-Known Member
    2017 TRD Off Road
    None yet
    This week, I'll be picking up a 1/2 yard of coarse sand for a paving project (about 1500lbs). The sand and gravel place is only a few miles from my home.
    Are there any nuggets of wisdom or warnings about hauling loose material in a 3rd gen Tacoma 5' bed? I'm thinking I'll want to lay in a tarp 1st to keep the sand out of all the gaps.
  2. Jun 15, 2021 at 6:04 AM
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    2nd tarp.
  3. Jun 15, 2021 at 6:13 AM
    Gutentight
    Gutentight Well-Known Member
    IL
    2021 Cement Off-Road 4x4 DCSB 3.5L AT
    Rent a utility trailer.
    Don’t have to worry about someone smashing your side with a bucket, cleaning all the grit out of every crack it swirled into on the drive, complaining about saggy ass rear springs after overloading (yeah check your door sticker 1500lb is beyond rated payload, and if it happens to be wet..). And it will be lower down to unload it
  4. Jun 15, 2021 at 6:21 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    That, or have the yard deliver. It may be cheaper and less inconvenient than the trailer rental. Besides exceeding payload, sand gets EVERYWHERE. And then there's not having to unload it...
  5. Jun 15, 2021 at 6:28 AM
    ian rogers
    ian rogers Well-Known Member
    Ian
    Sf Bay Area
    69 fj40, 2019 OR manual
    Locked Sliders Roll cage H41
    I put a towel on the back of the cab so the sand/gravel doesn’t hit the cab. With the 5’ bed the have to drop the load sideways into the truck.
  6. Jun 15, 2021 at 6:32 AM
    Tacocement5
    Tacocement5 Well-Known Member
    Northwest Indiana
    2021 Toyota Tacoma TRD Off Road
    If they are not very far from home I would just have them deliver. Delivery rates are normally pretty reasonable for short trips.
  7. Jun 15, 2021 at 6:46 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    This is borderline if the sand is dry, if wet I wouldn't do it. Depending on your trucks payload rating you're going to be overloaded by 200-500 lbs at least. For a short trip I might try it. In addition to a tarp air up all 4 tires to the max listed on the tires sidewall. Wash the truck afterward. A pressure washer will help get sand out of the nooks and crannies.
  8. Jun 15, 2021 at 6:50 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Have it delivered or rent a trailer.
  9. Jun 15, 2021 at 6:55 AM
    ian rogers
    Ian
    Sf Bay Area
    I can’t believe the amount of people saying have it delivered or rent a trailer. He has a truck it’s 1/2 a yard of sand. Put it in the bed and drive home.
    E-Paz 732NJ, willie2, jmneill and 9 others like this.
  10. Jun 15, 2021 at 7:00 AM
    F4ight
    F4ight Well-Known Member
    SLO
    The delivery fee will be less than the cost of new springs.
    cosmicfires and xxTacocaTxx like this.
  11. Jun 15, 2021 at 7:01 AM
    Knute
    Its not the volume.
    Its the material, loading at the yard, variable weight, overload, clean up.
    Sand gets everywhere, even places you don't expect. Ever have sex on a beach? I did once........
    E-Paz 732NJ, MadKatt, p_sando and 6 others like this.
  12. Jun 15, 2021 at 7:01 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    +1 on the tarp. I had to get 15 large bags of wood chips for the garden and some of the bags were already torn open. There was so much clean up, especially between the bed and tailgate.
  13. Jun 15, 2021 at 7:04 AM
    Mikro
    Mikro Well-Known Member
    2020 MGM TRD Pro
    If your rear sliding window is powered, cover it. My buddy hauled sand in his F-150 and had to have that rear window replaced bc sand got all in the internals in the drive home. Not to mention everywhere else the sand got.
    Gunshot-6A and danakinskyrocker like this.
  14. Jun 15, 2021 at 7:16 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Hauling sand sucks; that shit gets everywhere no matter how careful you are! There are times when it makes sense to "pay the man" and this is one of them!
  15. Jun 15, 2021 at 7:24 AM
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
    +1 on the "have them deliver it" votes.
    Also guaran-damn-tee you'll need more than you think resulting in multiple trips making it cheaper to just get it dumped in the first place.
    xxTacocaTxx and TacomaUSA like this.
  16. Jun 15, 2021 at 7:49 AM
    averagejp
    averagejp Well-Known Member
    2005 Black Tacoma Extended Cab
    Work in progress
  17. Jun 15, 2021 at 7:52 AM
    Knute
    At $20/bag, a couple of bags would be the delivery fee.
    Yes, you still have the bags. Now, you should clean them out and need to store them.
    averagejp likes this.
  18. Jun 15, 2021 at 8:20 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    The older I get the more time and energy has become more important than money.
    Tarps, shoveling, cleaning and cleaning again, the hazard of the yard loading -- just have it delivered and save your time and energy for the project.
  19. Jun 15, 2021 at 8:22 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It's not the weight it's the mess.
    Gunshot-6A and RustyGreen like this.
  20. Jun 15, 2021 at 8:25 AM
    SilverSkyTRD
    SilverSkyTRD Well-Known Member
    I would recommend getting it delivered, or buying bags, as others have mentioned. It feels like I am in an infinite loop of doing landscaping projects and always seem to be getting loam, crushed stone, stone dust, or mulch, delivered. Unless I had a dump truck I would not try to take it home in my truck. It's such a pain to get it out of the bed. Plus, if you're mid working and want to stop or go grab lunch, are you going to drive around with whatever material in there? If you get it delivered you can just work form the pile and not feel rushed. I laugh when I see guys at the local material yard pulling up in their pick up trucks and taking pictures. It's like pretending your pickup is a peterbilt has become a thing. Usually the damn bucket is as big or bigger than the truck bed which makes loading it cleanly a pain too.
