Hauling firewood: Rear suspension issue.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GT_Charlie, Nov 14, 2018.
  1. Nov 16, 2018 at 6:36 AM
    #41
    96carboard
    96carboard Well-Known Member
    Huh? Half ton is 1000 pounds, well within the payload allowance.
  2. Nov 16, 2018 at 6:42 AM
    #42
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I wouldn’t say well within.
    If you weigh around 200lbs and if you have one other person with you, some gear, maybe some tools, you can now only carry about 600lbs in the bed.
    I’m not telling you not to do it. I think people should know that they’re possibly overloading their truck without knowing.
  3. Nov 16, 2018 at 6:43 AM
    #43
    ajpagosa
    ajpagosa Well-Known Member
    SW Colorado
    2005 Access Cab TRD Off Road 6-speed manual
    That may be true on paper but having tried it myself on several occasions the leaf springs are noodles and once loaded handling was terrible.
  4. Nov 16, 2018 at 6:44 AM
    #44
    96carboard
    Uh huh, and WHAT ARE WE TALKING ABOUT HERE?
  5. Nov 16, 2018 at 6:46 AM
    #45
    96carboard
    1490 pound payload, minus a few hundred pounds is still over a half ton.
    And if you think that the payload sticker was set at a hard line where everything will suddenly crumple if you go 1 ounce over it, then you're seriously mistaken. There is at LEAST a 50% safety margin in there.
    tcjacado likes this.
  6. Nov 16, 2018 at 6:47 AM
    #46
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Any info on this? I’m genuinely asking, haven’t read anything about it.
  7. Nov 16, 2018 at 6:48 AM
    #47
    JMC3800
    JMC3800 Well-Known Member
    Western MASS
    2021 Off Road DCab
    You may want to consider a set of rear Sumo Springs they replace your bump stops.
  8. Nov 16, 2018 at 6:48 AM
    #48
    ajpagosa
    SW Colorado
    We are talking about what needs to be done to the Taco rear suspension to haul a lot of wood in the bed. My opinion is it is not as simple as just slapping on air bags or stiffer rear springs. I think we agree the rear susp from the factory can't cut it. I found, based on my own direct experience doing exactly what the OP asked about, stiffening up rear ONLY did not work well, that having a small trailer is preferable, and that the cost of doing it right susp wise is greater than the cost of the trailer. It just so happens I eventually did both (upgraded suspension front and rear) AND bought a trailer. I prefer the trailer for heavy hauling and the upgraded susp for doing other fun Taco stuff. Plus I can haul way more wood in the trailer than I could in the bed, and it is far easier to load/unload.
    edit: forgot this. I ended up blowing out the rear Bisltein OR shocks after hauling a few loads of wood in the bed, in addition to trashing the stock leafs. They just can't control all that extra weight very well. But then where I go to get wood is semi rugged SW CO mountains and hauling a big load out of there is a bit bouncy.
  9. Nov 16, 2018 at 6:49 AM
    #49
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I’ve overloaded my truck once and it was a pretty scary drive. I won’t be doing it again. I got a 4x8 trailer for $200.
    PzTank, llamasmurf and ajpagosa like this.
  10. Nov 16, 2018 at 6:54 AM
    #50
    96carboard
    That was only scary because you loaded it dangerously. You should lose your driver's license for operating like that on a public road.
    And its not the weight that made it dangerous, its where you PUT the weight -- looks like about 1600 pounds ALL BEHIND THE REAR AXLE!
    If you want to carry that much weight, its weight center needs to be AHEAD of the rear axle.
  11. Nov 16, 2018 at 6:56 AM
    #51
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    :duel:
    You live and you learn. And I definitely learned that day.
    Jaypown likes this.
  12. Nov 16, 2018 at 6:58 AM
    #52
    96carboard
    Good to hear.
    And you are at a bit of a disadvantage with the short bed... less space ahead of the axle to load it up.
  13. Nov 16, 2018 at 7:00 AM
    #53
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Yeah that’s when I learned about weight distribution and tongue weight...
  14. Nov 16, 2018 at 7:14 AM
    #54
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Then you shouldn't have got a Stihl with a part number ending in 1! 0 is where it's at. xx1 models are newer and have to comply with stricter emissions controls.
    I have a MS260 and it runs better than my dads MD291
  15. Nov 16, 2018 at 7:27 AM
    #55
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    take the money you would invest in any suspension and put it towards a trailer, a good trailer. It will be much more versatile than your truck. Used trailers are hard to come by, they go quick. i found a used karavan 5x8 for $650. Its capacity is 2000 lbs.
    ajpagosa and Alexely999 like this.
  16. Nov 16, 2018 at 8:31 AM
    #56
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    Stock leafs springs suck..... this was the 2nd time... eventually went with Dakars....
    96carboard likes this.
  17. Nov 16, 2018 at 8:44 AM
    #57
    96carboard
    DING DING DING!!! We have a WINNER!
  18. Nov 16, 2018 at 1:34 PM
    #58
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    spend your money on a real chain saw
  19. Nov 16, 2018 at 1:37 PM
    #59
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    I will eventually get a nice saw. When I need it.
  20. Nov 16, 2018 at 6:31 PM
    #60
    96carboard
    Eh, well.... to each his own, but I'm really not the kind of person to get all freaked out about a small variation resulting from more strict emissions requirements. *maybe* I might understand the perspective if we were looking at the biggest forestry saws that they made, but to put it plainly, if I needed something more *powerful*, I would have bought a bigger saw.
    And you know there is a lot more to how well a saw runs than just one having more strict emissions regulations impacting it than the other. If you want to compare the performance of two saws that are pretty similar in size, then you are going to have a bigger variation resulting from who is better at mixing the fuel, and who is better at sharpening the chain than you'll have from minor technical details.
