has anyones use this inflator from Ryobi?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by el_turks, Feb 16, 2016.
  1. Feb 16, 2016 at 7:01 AM
    el_turks
    el_turks [OP] Well-Known Member
    Southern California
    2024 OR, 2009 PreRunner
    http://www.homedepot.com/p/Ryobi-18-Volt-ONE-Power-Inflator-Tool-Only-P737/206159256
    The 18-Volt ONE+ Power Inflator is a new offering from the ONE+ system of over 50 great tools, available as a Special Buy while supplies last. This 18-Volt Power Inflator is perfect for tires and small inflatables ranging from 0-150 psi. The cordless convenience allows for use in virtually any location. The 18-Volt ONE+ Power Inflator is sold as a bare tool, allowing you to build on your ONE+ collection without spending additional money on batteries and chargers with each tool purchase. Best of all, like every Ryobi 18-Volt ONE+ blue or green tool, this Power Inflator works with any 18-Volt ONE+ battery. Upgrade to lithium-ion or LITHIUM+ batteries for lighter weight and better performance.
  2. Feb 16, 2016 at 7:05 AM
    Connormc11
    Connormc11 Jangler
    Connor
    Norfolk VA
    2010 DCSB TRD-Offroad
    My Brother works for TTI the company that owns ryobi and he gave me the prototype about a year ago to abuse and test. On a 33" tire it takes about 6 minutes if i remeber correctly to inflate from 15psi back up to about 36psi. It is not that fastest but will get the job done. I ran the thing non stop until the hose was too hot to touch to see if it would ever fail and it is still going strong. I would reccomend the higher amp-hour battery though. In the end, it wont ever be as fast as a vair set up, but if you already have ryobi stuff it is a great tool to keep tucked behind the seat.
  3. Feb 16, 2016 at 7:05 AM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Won't work on tires, unless you are just topping them off a few PSI during cold weather.
  4. Feb 16, 2016 at 7:10 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    According to the reviews, you have to hold down the trigger constantly, which would be a dealbreaker for me.
  5. Feb 16, 2016 at 12:32 PM
    el_turks
    Southern California
  6. Feb 16, 2016 at 12:34 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Turn off sigs.
  7. Feb 16, 2016 at 1:14 PM
    el_turks
    Southern California
    YOU MY SIR.... ARE A GENIUS!!! I did not know I could turn them off and I just did. Thank you.
    T4RFTMFW[QUOTED] likes this.
  8. Feb 16, 2016 at 1:19 PM
    T4RFTMFW
    It inflated my girlfriend too quickly, her eyes bulged which was kinda hot - but then she popped.
    I hadn't planned for that. It was a rough night for us.
  9. Feb 16, 2016 at 1:19 PM
    el_turks
    Southern California
    :eek:
  10. Feb 16, 2016 at 1:29 PM
    mray
    mray Well-Known Member
    Colorado
    2011 4cyl Base Access Cab 4x4
    +1 for the Viair...
  11. Feb 16, 2016 at 3:45 PM
    el_turks
    Southern California
    Changed my mind and I am buying this....
  12. Feb 16, 2016 at 3:49 PM
    KenLyns
    Belly of the Beast
    When you do her in your Tacoma, does it feel like a threesome?
  13. Feb 16, 2016 at 4:01 PM
    T4RFTMFW
    A gentleman never asks, and a lady never tells. @KenLyns
  14. Feb 16, 2016 at 4:05 PM
    T4RFTMFW
  15. Feb 16, 2016 at 4:42 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    Another vote for Viair. Mine screws onto the valve stem so you can walk away. Cord is long enough to hit all 4 tires from the cig lighter.
