Has anyone run the 58mm pulley?
Discussion in 'Performance and Tuning' started by Phantom5280, Jan 16, 2019.
  1. Jan 16, 2019 at 6:05 AM
    Phantom5280
    Phantom5280 [OP] New Member
    2004 Red Tacoma TRD
    S/C, Wheels
    If so what were your results. Are there any cons?
  2. Jan 17, 2019 at 10:00 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Don't know what truck, engine, or supercharger you're talking about. However if 58mm is smaller than the stock pulley, it's going to make more boost. That usually mean you have to start modding your fuel system and/or computer. Colder spark plugs perhaps too. The more boost, the more fuel and timing control you need. If you post your specs somebody else may have firsthand insight.
    TacomaSport86 likes this.
  3. Jan 17, 2019 at 9:36 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
  4. Jan 21, 2019 at 1:11 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Im guessing youre talking about the 1st gen trd supercharger?
    @eon_blue @elnip @1997tacomav6
    Just tagged some guys above that are all running small pulleys with their first gen TRD blower. Maybe one of them can chime in with more info
  5. Jan 21, 2019 at 1:13 PM
    BassAckwards
    Increased heat generated as the 1st gen blower does not have an intercooler. Also i believe it will require more fueling like the 7th injector
    elnip likes this.
  6. Jan 21, 2019 at 1:16 PM
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    ^^this^^
  7. Jan 21, 2019 at 1:16 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    no smaller pulley here, but @1997tacomav6 will have some good info on them. I think he's running the smallest one you can get without going custom.
    I still have occasional pinging issues so I don't want to tempt fate with a smaller pulley until that all gets ironed out
    BassAckwards[QUOTED] likes this.
  8. Jan 21, 2019 at 1:18 PM
    eon_blue
    Azusa, CA
    Yeah you will definitely need additional fuel mods if you want to run a smaller pulley. Methanol injection seems to be one of the best options for us 1st gens because it increases the octane rating substantially when needed to prevent pinging, and also does a great job of cooling the intake temps. 7th injector does an okay job of getting rid of the lean issues but doesn't do much if anything for cooling the intake. I still have crazy high intake temps with the 7th injector in the summer time.
  9. Jan 21, 2019 at 1:19 PM
    BassAckwards
    Just did a bit more reading and it appears the 58 mm pulley is for the 2rz/3rz.. So looks like I tagged the wrong folks lol :oops:
  10. Jan 21, 2019 at 1:20 PM
    elnip
    LC,NM
    Still applies! :cheers:
  11. Jan 21, 2019 at 1:22 PM
    BassAckwards
    :fistbump:
    1997tacomav6 likes this.
  12. Jan 21, 2019 at 1:36 PM
    1997tacomav6
    Denver
    Yup Im running a 2" pulley and the methanol covers the lean and ping issues with zero problems
