Has anyone here used Lucas Engine Oil Stop-Leak?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Mar 24, 2019.
  1. Mar 24, 2019 at 2:53 PM
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
    On my last trip to the dealer for an oil change, I was told I have leaking valve gasket. They wanted $850.
    I don’t have the tools or the experience for this job. I have a very good shop that will do this for me in San Diego, but I don’t know when I’ll have my truck down there next.
    I saw this stuff called Lucas Oil Stop Leak at Home Depot, and it swells gaskets for a temporary fix. If I use this to stop the white smoke from coming out of the exhaust (until I get down to SD), will it compromise other gaskets?
    Is this stuff trustworthy?
  2. Mar 24, 2019 at 3:19 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Only if you want to sell the truck this week and hide the problem from a potential buyer. If it swells the head gasket it will do the same to all seals where the oil is flowing. I see $$$ for engine rebuild.
    If you want to fix the problem, fix the gasket, not the oil.
  3. Mar 24, 2019 at 4:00 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Leaking valve cover gaskets will burn oil on the exhaust Manifolds .
    Not in the engine so any white smoke is in the engine compartment
    If your valve guides are leaking a whole other problem
  4. Mar 24, 2019 at 4:02 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    stuff like this are only a temporary fix. If you want to solve the problem for good, you have to fix the real problem, the headgasket
    also, since when does dropping goop in an engine solves problems? It will gunk up things other than the leaky gasket and may end up creating more damage
    Just as an example, my tractor had mystery overheating issues. I found out that the radiator was all gunked up because revious owner didn't bother replacing the leaky radiator and used stop-leak stuff instead. replaced the radiator and no more issues. It was expensive but it was well worth it, as it now runs like a brand new tractor, despite being 30 years old
  5. Mar 24, 2019 at 4:34 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just get it fixed as stated.
    Btw you mentioned two things that aren't exactly related - white smoke from your exhaust would mean you're burning coolant and you have a head gasket issue (smell the exhaust gasses coming out), valve cover gasket leaks would mean your oil would seep out and burn off on your exhaust manifold (burnt oil smell/smoking from the engine compartment).
  6. Mar 24, 2019 at 5:59 PM
    redbull9944
    redbull9944 Well-Known Member
    Southwestern PA
    2016 DCSBTRDOR Inferno 6MT, 2004 Double Cab 4WD Project
    Prinsu Rack, 275/70R17 Cooper ST MAXXs, TRD PRO 4Runner Wheels, 5100s
    I would call around other shops to get more quotes. A valve cover gasket + replacement runs $250-300 for this truck where I'm at. I have to get mine fixed soon as well. Nobody has quoted anything near what you said. That's crazy
    Cutter_[OP] likes this.
  7. Mar 24, 2019 at 6:07 PM
    tony2018
    tony2018 Well-Known Member
    I frown upon stop leaks, I'm just not sure how stop leaks of today are any different.
