Has anyone ever used a strut lift kit?
Discussion in 'Suspension' started by Relate_2_Nate, Jun 30, 2016.
  1. Jun 30, 2016 at 3:10 PM
    Relate_2_Nate
    Relate_2_Nate [OP] Active Member
    nate
    06 Toyota Tacoma
    Leveling kit 265/70/17 Nitto Terrigraps Winchready bumper 12,000 lb winch 22inch lightbar Spyder headlights Tint K&N Cold air intake
    I'm looking to get a kind of a cali squat on my 06 tacoma but i don't want it to be obnoxious. I want to put the rancho "quick lift struts" on and then put my existing leveling kit on top of the new strut so id get like an additional 2 inches of fit from what i have now. has anyone done this before or know if it would work? I'm just a bit nervous about putting them on because i don't want to add any stress on the front end.
  2. Jun 30, 2016 at 3:18 PM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    Horrible idea, the only thing you'll do is f up your front end. Your leveling kit is a strut spacer, you can't safely stack these.
    ODNAREM likes this.
  3. Jun 30, 2016 at 3:20 PM
    Relate_2_Nate
    nate
    06 Toyota Tacoma
    ok thanks! not trying to be ignorant or anything buy why can't i stack them? and any other cheap alternatives other than getting an all around lift?
  4. Jun 30, 2016 at 3:20 PM
    Nickel
    Diego
    2013 T/X TRD
  5. Jun 30, 2016 at 3:23 PM
    Nickel
    Diego
    2013 T/X TRD
    There's countless stories on here about the nightmare of spacer lifts. There are affordable alternatives, look up bilstein 5100's, these would actually preload the spring to force the suspension to hold your front end up higher.
    ODNAREM likes this.
  6. Jun 30, 2016 at 3:24 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Quick Lift struts can mount just fine to a spacer.
  7. Jun 30, 2016 at 3:25 PM
    T4RFTMFW
    He's not asking about adding a spacer to a spacer.
  8. Jun 30, 2016 at 3:25 PM
    T4RFTMFW
    5100s or those Quick Lift struts will both work.
  9. Jun 30, 2016 at 3:27 PM
    Nickel
    Diego
    2013 T/X TRD
    This guy would know way more than I. Sorry to misinform. I assumed it was another spacer.
  10. Jun 30, 2016 at 3:28 PM
    Relate_2_Nate
    nate
    06 Toyota Tacoma
    i do go off road so i really can't risk anything breaking
  11. Jun 30, 2016 at 3:29 PM
    Relate_2_Nate
    nate
    06 Toyota Tacoma
    so how could i get like an additional 1.75-2.5 inches of lift in the front (on top of the 2 that i already have now with the leaving kit)
  12. Jun 30, 2016 at 3:34 PM
    T4RFTMFW
    The same way you planned to. It's not going to ride very good, and you may have other issues doing so, but it's possible to do.
  13. Jun 30, 2016 at 3:41 PM
    Relate_2_Nate
    nate
    06 Toyota Tacoma
    any other ways around that?
  14. Jun 30, 2016 at 3:47 PM
    T4RFTMFW
    Your truck 4x4 or 4x2?
  15. Jun 30, 2016 at 3:49 PM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Are you 2wd? If so, remove your front lift, and do a spindle lift. I think that gets you about 4".
  16. Jun 30, 2016 at 3:50 PM
    T Fades
    Simi Valley, CA
    If you offroad, your idea in your OP will be a terrible ride and you will probably regret it.
  17. Jun 30, 2016 at 3:51 PM
    T4RFTMFW
    This is where I was headed with my last post.
    If you're 4x4, you need to get a real lift kit (drop bracket will be the only option if you want 4"+) and not try to do 2 things at once, or be happy with less lift. If your front can't be up high enough, lower your rear end.
  18. Jun 30, 2016 at 3:51 PM
    Relate_2_Nate
    nate
    06 Toyota Tacoma
    i have a 4x4. i don't do hardcore off road
  19. Jun 30, 2016 at 3:52 PM
    T4RFTMFW
    Pull out your wallet (drop bracket lift), don't lift so much, or have a diminished ride quality and go with a Quick Lift/5100.
  20. Jun 30, 2016 at 3:53 PM
    Relate_2_Nate
    nate
    06 Toyota Tacoma
    and another reason i wanted to lift it was because i want to go up to 285 tires and i don't want them to rub in the front (i currently have 265)
