Has anyone else had terrible luck balancing M/T's at Discount Tire?
Discussion in 'Off-Topic Discussion' started by TacoSauceHB, Jul 14, 2022.
  1. Jul 14, 2022 at 6:27 PM
    TacoSauceHB
    TacoSauceHB [OP] Well-Known Member
    Brian
    Rathdrum, ID
    2017 _TRD Off-Road DCLB 4X4 Tech Package
    King 2.5 ext travel, Camburg uniball UCA, SCS Ray10 wheels, 285/75/16 Cooper STT Pro's, CMC , MBRP exhaust, K&N cai , OVTune 1.05 , T-rex billet grill, Rigid DS Pro ditch lights, SDHQ ditch light brackets, Leer 100XQ Shell, ShmellFab Sliders, Victory 4x4 Roof rack, LED headlights. SOS Concepts bumper, Smittybilt X20 Winch, Nitro 5,29 gears, ECGS clamshell bushing.
    I just bought a new set of Cooper STT PRO's ( 315/75/16 ) and yes I re-geared, CMC, and OVtune :thumbsup:. Also had an alignment done right before install. However, I have put about 2,000 miles on these and cant seems to get them balanced correctly. I have been back 4 times now to Discount Tire and they are using a road force balancer but I still get a pretty bad vibration from 45-50mph and gain at 65-70mph. Just curious if anyone else has had an experience like this with DT. Going to a different shop on Monday that specializes in bigger trucks and M/T tires so ...
    :fingerscrossed:
  2. Jul 14, 2022 at 6:37 PM
    Bishop84
    Bishop84 Well-Known Member
    It's the nature of the beast.
    Drive them, wear them down a bit, then rebalance them.
    IvanhoeTaco and Wulf like this.
  3. Jul 14, 2022 at 6:41 PM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Have you tried a different shop?
  4. Jul 14, 2022 at 6:42 PM
    TacoSauceHB
    Brian
    Rathdrum, ID
    The thing is, this is probably my 6th set of Cooper M/T's and you always get some mild vibrations from a 10ply tire on a mid size truck but this time its bad. My bed looks like its twerking when I hit those 2 speed ranges :taco: lol. Ill post an update after I have this other shop check it out.
  5. Jul 14, 2022 at 6:42 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    I jave coopers as well, 33, Discount Tire did a great job on mine, but i get them rebalanced at evwry rotation, and its needed.
    For tires as big as you have, id just go straight to balance beads. Thats how i balanced my 35 inch Coopers, same mud tire, on my old Xterra, never an issue. And never a need to rebalance.
    TacoSauceHB[OP] likes this.
  6. Jul 14, 2022 at 6:42 PM
    TacoSauceHB
    Brian
    Rathdrum, ID
    Going to one on monday so hopefully they can get it dialed in.
  7. Jul 14, 2022 at 6:43 PM
    TacoSauceHB
    Brian
    Rathdrum, ID
    How exactly do these beads work? I heard about them before with tires 35 and up.
  8. Jul 14, 2022 at 6:45 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Mud tires are always harder to balance. And they are harder to manufacture and get them round. There is a good chance you have at least one tire that is defective and causing the problem.
  9. Jul 14, 2022 at 6:46 PM
    Mark77
    Mark
    Nothing yet
    Google
  10. Jul 14, 2022 at 6:48 PM
    TacoSauceHB
    Brian
    Rathdrum, ID
    good point. I had a set of Toyo M/T's and that exact thing happened. They also pulled to the right no matter what they did so I returned them and went a different route. If this new shop confirms that I'm bringing proof back to Discount Tire and demanding a new set lol
  11. Jul 14, 2022 at 6:51 PM
    Smokestacks
    BayArea
    I think it’s like slime tire repair. Cooper is a good brand I’m sure the next shop will figure it out. Or let you know one is defective.
  12. Jul 15, 2022 at 9:29 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    I too had a shake from 52-58 on my coopers. Went away after a few thousand miles a rotation and re balance had me squared away. 20k later it's back. Just an MT thing. I notice it worse on bad roads. Smooth road it almost doesn't happen
