Has anyone done elec fans?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dbs1, Jun 19, 2011.
  1. Jun 19, 2011 at 4:15 PM
    dbs1
    dbs1 [OP] 2015 Dbl cab TRD Pro 4x4
    Dan
    2015 Dbl Cab TRD Pro 4x4
    SC w/urd pulley, afe cai, URD LT's, TRD cat back. 375hp. Custom logos, tonneau cover, westin bar with piaa lights, aero force gauges, custom front air dam, Westin step bars.
    I have an 06 4.0 engine 4wd access cab that could use some more ponies and better fuel economy.
    On my wife's 08 gmc envoy denalli with the 5.3 v8 I changed out the mechanical fan for an elec one and saw a 10 hp gain and over 2 mpg better.
    Has anyone done this with the 2nd gen 4.0 Tacoma? Gains? Best unit to use?
    Thx for any input.
  2. Jun 19, 2011 at 5:01 PM
    olgzr
    olgzr Well-Known Member
    Denton, Tx
    I have not tried this but am interested in doing the same if there is a kit available that improves available horsepower or mileage.
  3. Jun 19, 2011 at 5:02 PM
    mudthedoor
    mudthedoor Sconnie
    Alex
    Forestville, WI
    00 4Runner
    Hmmm... interesting...........
  4. Jun 19, 2011 at 5:03 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I know a couple people that have them. Flex-a-lite is the manufacturer of choice... Both said that it freed up some power but damn are they loud when they kick on!!!
  5. Jun 19, 2011 at 7:59 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
  6. Jun 20, 2011 at 7:17 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I've had the Flexalite kit on mine for 2 years now. I didn't notice any performance or mpg gains, just a quieter startup (no fan roar on startup). As for loud, I don't notice it being any louder then the mech fan when it's turning, but I do notice the electric more since it cycles on/off more often then the mech fan does.
    I added some rubber washers as isolaters on the fan to support connections as the elec fan did seem to resonate through the frame on startup without the rubber washers in place.
    I also added a 2-stage fan controller to reduce the full off/full on amp draw on the fan.
  7. Jun 20, 2011 at 7:32 AM
    memario1214
    Colton
    Missoula, MT
    Hmm... Good idea. I have been throwing the idea around but haven't really landed on anything that tells me I need an elec fan yet. If I could change it so that it's not full on/off I might be interested. What did the kit and everything run you if you don't mind me asking?
  8. Jun 20, 2011 at 7:49 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Why would switching to electric fan give any HP or MPG gain ?:confused:
  9. Jun 20, 2011 at 7:52 AM
    memario1214
    Colton
    Missoula, MT
    A belt driven fan causes constant drag on the engine. Kinda like going out for a run with a little parachute behind you...
  10. Jun 20, 2011 at 7:53 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    At the time the Flexalite kit was $400. I added the 2 stage controller (Flexalite again) about a year later for I think it was $95. Sooo, definitely not cheap and the returns are very difficult to justify. I think the Flexalite kit is now about $350 though.
    I'm sure something could be pieced together cheaper, but I didn't want to get into homemade mounts and fabbing.
  11. Jun 20, 2011 at 7:54 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Because it is not running off of the engine itself but electric (alternator) instead.
  12. Jun 20, 2011 at 7:55 AM
    BlueT
    NorthEast
    it only drags when temp is high enough to lock the clutches otherwise its just free wheels
    But if temp is high enough then I would assume electric fan is kicking in too.
    since electric fan is driven by power from alternator that will will create drag too.
    and now you have heat loss at alternator and electric motor of the fan.
  13. Jun 20, 2011 at 7:56 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Less parasitic drag on the engine.
    Edit - Never mind, too slow.
  14. Jun 20, 2011 at 8:00 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    I've got a custom setup on mine... First of all I will say does it make a difference with HP or MPG..... NO. There isn't enough drag on the motor to even notice the difference.
    The main benefit I do like about it is quick warm up's in the winter. There is no real drop in solution in my eyes for these trucks though. Flex-a-lite makes one that works for our trucks however the shroud on it covers maybe 2/3's of the radiator which is far from ideal for sure.
  15. Jun 20, 2011 at 8:06 AM
    memario1214
    Colton
    Missoula, MT
    And that's the other thing I was thinking... So is there REALLY a benefit here? Dunno
  16. Jun 20, 2011 at 8:09 AM
    BlueT
    NorthEast
    Yeah I dont know where people are getting the MPG and HP gains. If anything mechanical is probably more efficient. But I am interested in winter piece, pluss my issue is when goign through rough terrain I am on low RPM's so I dont think truck is getting enough cooling. I would love to be able to run fan at full speed even when truck is idling.
    Anyway can you post pics of custom setup? Some people installed Ford Taurus dual electric fans. Is that what you have ?
    functionality benefit but probably at higher fuel cost and lower HP...
  17. Jun 20, 2011 at 8:10 AM
    runyun
    runyun Well-Known Member
    Irving/N. Grand Prairie
    02 Silver TRD DC
    Id like to add an electric fan, push style, in front of my condensor.
    I live in hot texas and noticed when the truck is stationary, the air conditioner is not as cold.
    With an electric fan setup, it would keep the a/c cooler by moving air through the condensor. Any thoughts?
  18. Jun 20, 2011 at 8:15 AM
    Fire931
    VA
    00 4Runner
    Hopefully to answer some of the other questions....
    When wheeling I run my fan at full speed all the time because typically I'm doing low RPM high load stuff... Plus if wired correctly it gives you the option to turn it off if doing a high water crossing to prevent damage and motor stalls.
    As for the summer time stuff.... Yes an electric fan will keep the AC blowing ice cold even sitting in traffic or whatever....
    So overall does it have some benefits... YES... Are HP and MPG gains one of those.... NO :D
  19. Jun 20, 2011 at 8:16 AM
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
    I would say other than the noise my fan puts off it has been a huge help on gas milage!
  20. Jun 20, 2011 at 8:17 AM
    memario1214
    Colton
    Missoula, MT
    EDIT: Fire answered it
