Has anyone cut open a YZZG2?
Discussion in 'Technical Chat' started by Michigan Curmudgeon, Jan 22, 2017.
  1. Jan 22, 2017 at 9:56 AM
    Michigan Curmudgeon
    Michigan Curmudgeon [OP] Well-Known Member
    Consensus on BITOG is that the 90915-YZZG1 oil filter is Purolator made.
    Apparently, 'D' in a filter part number means 'Denso'. Those filters are made in Thailand.
    'G1' means USA made, and again 'apparently' very much resemble Purolator filters down to the date code stamped on the end of the filter.
    How about the currently available 'G2" suffix? Does this also resemble a Purolator or did they go to a different maker?
  2. Jan 23, 2017 at 3:56 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    If you cut one open, you'll find there is a difference. One of our mods did that a few years ago..... Go with genuine Toyota filters.
  3. Jan 23, 2017 at 5:34 PM
    Michigan Curmudgeon
    Thank's for the reply, but I'm not sure it tells me much.
    The 90915-YZZD1, D3, G1, G2 are all 'Genuine Toyota Filters' and all will fit my 2TR-FE.
    The 'D' series has been established as Denso made, and the G1 is speculated to be Purolator contract made.
    There are writeups on all except the currently available G2.
    That's the info I seek. Is the 'G2' the same internally as the 'G1'? If it's different, what's the best guess on the maker?
  4. Jan 23, 2017 at 5:44 PM
    Muffdiver
    Muffdiver Growing old is mandatory, growing up is optional
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
  5. Jan 23, 2017 at 5:49 PM
    Michigan Curmudgeon
    I have that information.
    It concerns the Denso made filters.
    Toyota also contracts to have filters made in the USA. They are not Denso made.
    Specific information sought is about the 90915-YZZG2.
  6. Jan 23, 2017 at 5:59 PM
    Muffdiver
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
    Good luck on finding what you're after. Thought that thread may have been it.
  7. Jan 23, 2017 at 6:04 PM
    presta24
    presta24 Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
  8. Jan 23, 2017 at 6:12 PM
    RedRed
    RedRed TACO TUESDAY!!!
    Red
    Lake Norman NC
    15 taco with stuff & things
    1.75" Billy's plus 1/4 spacer on both sides. 1" block in rear. 265/70/17 nitto g2 SCS matte dark bronze 6s
    FYI 75% of your truck is made by DENSO
    presta24 likes this.
  9. Jan 23, 2017 at 7:49 PM
    Michigan Curmudgeon
    Uh huh. Most of the electric components, as it turned out, on my 1989 Dodge Dakota were made by Nippon-Denso also. Toyota owns most if not all of Denso.
    I did go back and look at the thread muffdiver referenced, a lot has been added to it since I last looked. Thanks, I'm not ungrateful for link. I need to sort through that to see if a G2 is in there someplace.
    The Japanese guy speaks better English than I speak Japanese, but we still can't communicate. What I got out of that is that there are 3 Toyota branded filters with the same part number built to 3 different patterns. Incredible. The middle one is the Denso-Thai, the others I personally can't identify.
    This may be a fools errand if you can't tell what's in the can by the part number.
