Has Anyone Been Successfull in Programing Dash Backlights Through Tech Stream Software?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CohoDan, Jan 29, 2020.
  1. Jan 29, 2020 at 2:54 PM
    CohoDan
    CohoDan [OP] Member
    Dan
    2020 Tacoma Sport
    Love my new 2020 Tacoma Sport, but would really like to get the dash Back Lighted with the headlight switch in "Auto" position. I find I must turn on the running lights or headlights in order to read the gages in sunlight conditions while I am wearing sunglasses. I have owned a 2007 Avalon, 2011 Avalon, 2014 Highlander XLE and currently own a 2019 Highlander XLE. I found that all of them had bright, backlit dashboards when the headlight switch was in "Auto". I wrongly assumed this was a Toyota design principle.
    I have seen a couple of threads talking about programming through Tech Stream software that the dealers all use for service. Has anyone actually done it and if so, what is the parameter number. I would like to educate my dealer on how to do it if it is possible.
    Thanks for your help.
  2. Jan 29, 2020 at 2:55 PM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    I didn't see anything pertaining to that when I was hooked up to my truck, I could have missed it though because I wasn't looking for it
  3. Jan 31, 2020 at 3:19 AM
    CohoDan
    CohoDan [OP] Member
    Dan
    2020 Tacoma Sport
    Thanks for your reply.
  4. Jan 31, 2020 at 6:52 AM
    Shellshock
    Iowa
    you can adjust the adjust the brightness. There’s a knob for it.
    GreyBaldTaco likes this.
  5. Jan 31, 2020 at 1:36 PM
    CohoDan
    CohoDan [OP] Member
    Dan
    2020 Tacoma Sport
    The backlight brightness is already all the way up. It only provides adjustment in the running light and headlight positions. My problem is I would like the dashboard backlighting to be on in "Auto" headlight mode.
  6. Jan 31, 2020 at 1:47 PM
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Just run a jumper wire, do we have a cluster and headlamp switch diagram?
  7. Feb 1, 2020 at 4:29 PM
    CohoDan
    CohoDan [OP] Member
    Dan
    2020 Tacoma Sport
    That is my last resort. I am trying to keep the warranty on my $43,000 two week old truck intact. I am hoping that it can be done using Tech Stream by the dealer. So far, does not look promising.
  8. Feb 1, 2020 at 4:31 PM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    You can adjust the sensitivity of the “auto” function. Check your owners manual.
  9. Feb 4, 2020 at 5:14 AM
    CohoDan
    CohoDan [OP] Member
    Dan
    2020 Tacoma Sport
    I have already done this. Still does not solve the problem of no backlighting in daytime when wearing sunglasses unless you manually turn the lights on.
  10. Feb 4, 2020 at 4:11 PM
    caribe makaira
    Caribbean, Puerto Rico
    Not a Tech Stream solution, a physical one:
    Identify the PANEL fuse (5A Brown)
    Remove the 5A fuse.
    Identify the side to the circuit (1A_55) and the power source side on the fuse panel.
    Get 2 add-a-fuse and crimp them.
    Select an IGN ONLY source at the fuse panel.
    One add a fuse will have the selected IGN ONLY fuse on the bottom slot of the add-a-fuse, the top will need a 5A one.
    On the other add-a-fuse, the bottom slot will remain EMPTY. The top will also have a 5A fuse.
    Place this one correctly, since you'll be bypassing the Parking/Tail/Illumination relay power source.
    The tapped IGN ONLY source will power the dash illumination at start up. (You will not have the choice of dash illumination OFF while vehicle is ON.)
    This will power the combination meter to do what you want, illuminate without the Parking/Low Beams ON.
    I am unaware of internal conflict of the AUTO lights since it's function is to provide a ground to the Parking lights and Headlights circuit via the sensor setting.
    I do not know if the system will interpret and CEL due to having power to the Combo Meter before the sensor input provides it. (low light parking, lower light headlamps)
    It's just a suggestion...
    AKGSD, Skydvrr, Two4Runner and 2 others like this.
  11. Feb 4, 2020 at 4:17 PM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    Leave drl on or headlights switch to on. They auto shutoff anyway when you turn truck off and exit and the timer runs out.
    CG256 likes this.
  12. Feb 4, 2020 at 4:24 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Tag for potential solution, I have this same problem. Do not understand why the cluster isn’t backlit during the day.
  13. Feb 4, 2020 at 5:54 PM
    HVLA
    HVLA Well-Known Member
    Idaho
    2020 Voodoo Blue OR DCSB 6MT
    Exactly. Why is this an issue? Leave the drls or headlights on always.
    GreyBaldTaco and CG256 like this.
  14. Feb 4, 2020 at 7:16 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Ever see a car driving around in the dark with only the DRL's on? That's why. No backlit dash means no lights.
    RocTaco, BearWithMe and toofast4u752 like this.
  15. Feb 4, 2020 at 11:25 PM
    BearWithMe
    BearWithMe Well-Known Member
    Four Corners
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    Agree, I would be upset if my Taco had 24/7 backlit gauges. I thought that concept died in the mid-2000s with Nissan and their porthole gauge cluster...
    What exactly do you need to see in daylight with sunglasses on? Isn’t the large, digital speedo enough?
  16. Feb 5, 2020 at 12:23 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    It must be a huge inconvenience to have to turn your headlight switch from auto to parking light to get the cluster to illuminate. And then to have to remember to turn it from parking lights back to auto or on when it’s dark out.
    3rd world problems.
  17. Feb 7, 2020 at 2:09 PM
    CohoDan
    CohoDan [OP] Member
    Dan
    2020 Tacoma Sport
    No problem at all. Just really irritating. Why does Toyota treat the Tacoma like an orphan compared to all the other cars they make.
  18. Feb 16, 2020 at 7:07 AM
    CohoDan
    CohoDan [OP] Member
    Dan
    2020 Tacoma Sport
    I want to thank everyone for their replies. I have written and spoken to Toyota in Texas, had my dealer check into this (while online programming an extra key fob) and no one has replied that they have successfully done this via programming. Apparently, it cannot be done. The post from Caribe Makaira showing how to do this by hard wiring appears to be the only alternative. For now, I will just live with the poor design. At least the speed display between the tach and speedometer is visible with sunglasses, turning up the brightness all the way. Thanks again to everyone who replied.
  19. Feb 16, 2020 at 8:29 AM
    HVLA
    Idaho
    No. The alternative is just to leave the drls or headlights on while driving.....
  20. Feb 16, 2020 at 11:51 AM
    caribe makaira
    In YOUR year/version truck, you get the dash to perform like the OP wants when the DRL is selected?:popcorn:
    TimC likes this.
