Has anyone applied Nyalic for corrosion protection?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRDProOne, Feb 15, 2020.
  1. Feb 15, 2020 at 7:26 AM
    TRDProOne
    TRDProOne [OP] Well-Known Member
    CA
    2019 TRD Pro in Super White
    Originally developed over 50 years ago for the Apollo space program. Curious if anyone has used this clear, glossy, flexible resin that dries hard in their Tacoma wheel wells. It looks promising and is used in many industries such as agriculture, etc. I just ordered some and will be applying it soon. I will report back soon with the finished results.
    https://www.nyalic.com/Automobiles-_c_21.html
    https://www.youtube.com/watch?v=42FeZumLVq0
    Chief007 likes this.
  2. Feb 15, 2020 at 7:29 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I'm a Krown Rustproofing fan for life, but Nyalic looks very interesting, as I've never heard of it before.
    Great idea~
  3. Feb 15, 2020 at 7:30 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I'd just be worried about shit getting underneath it. Make sure u post your results!
  4. Feb 15, 2020 at 7:36 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    Do spacecraft rust?
    I'm a big fan of 3M Cavity wax
    shakerhood likes this.
  5. Feb 15, 2020 at 7:44 AM
    TRDProOne
    CA
    The big pro that I like is that it dries glossy and hard. Dirt and grime won’t stick to it like Fluid Film, etc. It appears to act like a flexible but hard clear coat for the undercarriage.
    Tacoman97 likes this.
  6. Feb 15, 2020 at 7:45 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I'd be afraid shit would get underneath it and rust. Much like a rubber undercoating
    Scotty61 likes this.
  7. Feb 15, 2020 at 7:59 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I like that stuff too, does a great job covering and is not a sticky mess, also doesn't smell like a chemical factory.
    Itchyfeet[QUOTED] likes this.
  8. Feb 15, 2020 at 8:54 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    The problem with a hard coat (including paint and rubberized undercoating) is that it is impossible to get complete coverage on an assembled vehicle. Eventually the uncoated areas will start to rust and that will creep under the hard coating (which will trap moisture and make things worse).
    There's also the problem of properly preparing the surface to receive the hard coat.
    I used to use a 2 part paint product but I was probably only covering half (at best) of what needed to be coated.
    Now I start with a clean vehicle and spray a soft coating using various wands to get full coverage. I use Fluid Film but there are lots of oil and/or wax based options.
  9. Feb 28, 2020 at 12:51 PM
    TRDProOne
    CA
    My 3-can order came in the mail last week. I scrubbed my fender wells squeaky clean, let it dry for 3 days then sprayed on Nyalic.
    The Nyalic is a water-clear, flexible, hard-coat resin that provides permanent clear coat protection. It is not a wax, paraffin, polish or any other type of sacrificial coating. When properly applied it will not yellow, crack, peel or flake.
    2.5 spray cans later and here are the results. I also sprayed my differential but did not take photos...
    Before
    After Nyalic
    Chief007 and Evomike1 like this.
  10. Feb 28, 2020 at 12:57 PM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    So if it’s hard, what happens when a rock gets thrown up? Does it chip? Crack? Begin to flake?
    abodyjoe likes this.
  11. Dec 25, 2023 at 5:51 AM
    Evomike1
    Evomike1 Well-Known Member
    Glenwood Springs, CO
    2017 Tacoma Off-Road
    how did this go for you? I used it on my bilstien shocks bc they were famous for rusting. So far about 3 years later they are great! I just used it on the re-powder of my rear bumper... Super curious about your results
