Has anybody done Elbe Hills in their Tacoma?
Discussion in 'Off-Roading & Trails' started by Ozark_RegCab, Jan 12, 2024.
  1. Jan 12, 2024 at 6:53 AM
    Ozark_RegCab
    Ozark_RegCab [OP] Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I was talking to someone from Washington state the other day who was saying “the only Tacomas that can keep up around there are SASed.” This sounded like BS to me since I’ve done some pretty gnarly stuff in my basically stock 96 Taco.
    I’d bet a good driver in an IFS Tacoma with a rear locker and good tires could out-wheel one of these gung-ho types that insist you need Dana 60/14 bolt boat anchors bolted to your truck to go off pavement. What gives?
  2. Jan 12, 2024 at 8:45 AM
    longhairedhippy
    longhairedhippy I never go full redneck
    Ray
    Seattle, WA
    2019 MGM TRD OR SB
    Bunch of stuff bolted on, some cool, some not
    You could probably make it with a winch and a healthy disregard for body damage. The biggest issue I've run into is my 33" tires are just not big enough for the rocks in a bunch of the parks here, anything less than 37s is just going to be sitting on the center skid plates.
  3. Jan 12, 2024 at 9:03 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Yes if you can fit big tires on IFS and hold it all together, it can actually perform better than a solid axel due to the extra clearance.
    https://m.youtube.com/watch?v=w2uCP-NkhEk
  4. Jan 12, 2024 at 6:20 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    I've run elbe but not in my Tacoma. PNW is all about tire size. It's lots of mud and rock. You need tall wide tires. Id say minimum 35s unless your gonna full send it with no shits to give. Then again alot of people don't realize how good IFS can be. You just need to keep the suspension very soft so you can fully cycle it through the rocks. Alot of lifted tacos are too stiff and won't flex out enough and get stuck.
  5. Jan 12, 2024 at 6:29 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Is it all that gnarly up there though? I'm seeing plenty of mild to moderate tracks on Onx. The kind of stuff you're talking about, you might as well just build a tube buggy that you don't have to worry about rolling.
  6. Jan 12, 2024 at 6:32 PM
    CadCamMan
    CadCamMan Well-Known Member
    Mission Viejo, California
    2011 DCSB, 4WD TRD OR, 2.5 Kings
    TRD SC, suspension
  7. Jan 12, 2024 at 6:33 PM
    tacoman2001$
    There are some mild trails. Busy wild and such can be a real pain. Really depends on the weather too. Snow or alot of rain can make everything alot harder. There are definitely trails for more stock rigs though.
    Ozark_RegCab[OP] likes this.
  8. Jan 12, 2024 at 6:38 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
  9. Jan 12, 2024 at 6:40 PM
    tacoman2001$
    The biggest difference was he went from 35s? to 44s. that jump made the trail look pretty easy. On the solid axle he seemed to drive a bit more aggressively though.
