harmonic balancer oil leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by ElTaco88, Nov 7, 2023.
  1. Nov 7, 2023 at 5:17 PM
    ElTaco88
    ElTaco88 [OP] Member
    2004 black tacoma
    lofted
    if i have a leak on the harmonic balancer can it cause it to fling everywhere?
  2. Nov 7, 2023 at 5:26 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    likely the oil pump seal
    When I replaced, the seal came with the AISIN rockauto oil pump
    mine (as u can see) was leaking like stuck pig
    As well as T-cover gaskets/oil pan/distributor O-ring/valve cover
    glad that project(s) are over
  3. Nov 7, 2023 at 5:58 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    God... it is such a mess....everything in a constant plane gets soaked....
    right at the front of your new alternator......thats the plane....
    Since there is no oil in that pulley......there's three sources for oil out of that area...
    1st....and most common is the oil pump cookie gasket has turned to dust.......
    and now you have 'little Niagara' of oil.....
    2nd) very rarely the front main seal fails....timing cover has to come off...
    3rd)......and worse scenario is the harmonic balancer has wore out and has wobbled enough...
    too crack the inside of the timing cover where the oil pump gear sits and meets the harmonic balancer seal ....on the back inside of the timing cover..
    and that one will be a curved hair line crack right at the crankshaft base on timecover backside......that is the devil to find.....
    If you've tightened up your HB.....and it still wobbles ....a lot....its probably too late...
    Wonder how I know all this.........some nites...nightmares....all nite long......
    I need therapy.............or a 4-runner to restore......
    1997tacomav6 and ControlCar like this.
  4. Nov 7, 2023 at 6:09 PM
    ControlCar
    Steven
    Sugar Land TX
    Ha Ha!
    believe me Silver
    That 5 day project was PITA
    Still washing out those grease/oil chips out of the hair I still have.
    Ruined 3 shirts/1 pair of shorts
    (They are rags now)
    no leaks
    No left over bolts
    Thou
