Harmonic Balancer Bolt
Discussion in '1st Gen. Tacomas (1995-2004)' started by Funkychateau, Jun 3, 2024.
  1. Jun 3, 2024 at 10:38 AM
    Funkychateau
    Funkychateau [OP] Well-Known Member
    Martin
    1999 Tacoma 2WD Extended Cab
    None
    1999 SR5 2.4 Automatic
    Can someone tell me for certain whether my harmonic balancer bolt is standard right-hand threads?
    I understand I’m going to need to really bear down with the impact wrench to break it loose. I want to be confident that I’m not tightening it.
    I’m also replacing all three belts, but are there any other things I should check or replace that are made easier by having the crankshaft pulleys off?
    Someone told me I should replace the crankshaft position sensor. Is it under that cover behind the harmonic balancer?
    Truck has 397,000 miles, and hasn’t had any engine repairs.
    thanks!
  2. Jun 3, 2024 at 10:55 AM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    https://youtu.be/KxthKmWQvos?si=PjugFXHN7Poc_EGq
    Yes, righty tighty and lefty loosey. Your hurdle will be retightening it. May want to buy a crank bolt socket. With my manual I just put it in 5th gear, had my wife stand on the brake and gave it all I had with a breaker bar. Paint pen marked bolt and HB and it hasn’t moved almost a year later.
    Think it’s something like this.
    https://www.amazon.com/Toyota-Crank...efix=toyota+crank+bolt+socket,aps,238&sr=8-18
    Good luck.
  3. Jun 3, 2024 at 11:35 AM
    Funkychateau
    Martin
    None
    Thanks for the quick reply. I skipped to the end of that video, and it appears that the bolt has right-hand threads. Am I correct?
    Using the starter to loosen the bolt is a cute idea if you have an automatic, which I do. Too bad it can’t be made to spin the motor in reverse ...
    The tool you linked prevents the engine from turning by attaching to the HB, which is splined to the crankshaft, and you use a second breaker bar to hold the tool? Maybe Autozone will loan me that tool ...
    Is there an actual torque spec on that bolt, or is it just “tight as you can get it”? The impact wrench I have is rated 1170 ft-lbs breakaway and 880 tightening. That seems like it might be excessive.
  4. Jun 3, 2024 at 12:09 PM
    THatt
    Upstate SC
    Yes right hand threads. Yes supposed to hold the HB and shaft stationary while bolt is torqued. There is a torque value, you’ll have to search it. Think it was like 210 flbs. Believe FSM calls to replace bolt but I put original back and just scribbed a mark for reference, put all I had in me to tighten it. I’m about 210.
    And I was as nervous as a whore in church with that crank bolt loosing trick but it worked like a champ. Just take your time and make dang sure everything is aligned and tied off before you try it.
    Funkychateau[OP] likes this.
  5. Jun 3, 2024 at 12:57 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
  6. Jun 3, 2024 at 1:58 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    me and Thatt have both helped each other with our CS bolt removal and install
    Thatt sold me on the use of a crank shaft holder to properly tighten CS bolt(and to mark bolt/pulley for any movement)
    i turned Thatt on that above vid for removal
    i was really surprised:
    -how easy starter method vid worked
    -how much additional torque i got on CS bolt with holder(like almost a 1/2 a turn of the wrench
    ireymon, Funkychateau[OP] and THatt like this.
  7. Jun 3, 2024 at 2:25 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I used the breaker bar method on my old 1st gen.....
    Made the loudest crack ever.
    Scared the shite out of me.
    Broke it loose, though.
  8. Jun 3, 2024 at 2:28 PM
    O'Silver_Taco
    MD
    Lucky bastards......when I bought that tool 4 yrs ago they were $50...
    the rear axle seal tool is almost half price too....use to be $110 with ring tool/attachments...
    bkhlrTaco's likes this.
  9. Jun 3, 2024 at 2:30 PM
    ControlCar
    Steven
    Sugar Land TX
    that is the 1st time i have heard of ANYTHING going down in price in last 4yrs!!!!!!!!
    OS plz send me a link to that rear axle seal tool whenever you get time
    thanks!!
  10. Jun 3, 2024 at 2:30 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I hear that.
    They were around $80 when I fixed mine...
    That's why I went breaker bar. :D
  11. Jun 3, 2024 at 2:32 PM
    O'Silver_Taco
    MD
    ControlCar likes this.
  12. Jun 3, 2024 at 2:35 PM
    ControlCar
    Steven
    Sugar Land TX
    u da man
    from those Timmy vids you sent me.........i know there is an extra step for ABS tone ring
    QQ
    would tht tool work for no ABS?
    thanks again
  13. Jun 3, 2024 at 2:36 PM
    O'Silver_Taco
    MD
    Of course the really expensive piece is the 20ton floor press
    that axle press tool fits all...
    and those thick extra steel pieces come in handy on a press for other things...
    Used to be able to get HF 20ton for around $150 with coupons....
    ......NOT NO MORE....
  14. Jun 3, 2024 at 2:36 PM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    On my 2001 the thermostat and water pump are in there.
    Can by it as a kit, if I remember right.
    Might as well replace them while you're that deep in.
  15. Jun 3, 2024 at 2:38 PM
    O'Silver_Taco
    MD
    IF your at that point I'd do a new oil pump gasket....
    and possibly a water pump...
  16. Jun 3, 2024 at 5:48 PM
    Funkychateau
    Martin
    None
  17. Jun 3, 2024 at 6:02 PM
    THatt
    Upstate SC
    The down side is y’all ain’t closer to share a beer with.
  18. Jun 3, 2024 at 7:02 PM
    Funkychateau
    Martin
    None
    I just ordered the tool you recommended. Should have it in a couple of days. Hopefully this will be preferred to pulling the radiator to use an impact.
    THatt[QUOTED] likes this.
  19. Jun 14, 2024 at 2:30 PM
    Funkychateau
    Martin
    None
    OK, I have the crankshaft-holding tool in hand, truck on ramps, fan shroud and all belts off. I had to partially drain the radiator so I could take the top hose loose and pull the fan shroud out the top. Didn’t see an easier way.
    Once I got under the truck, I was getting dirty so fast I decided to pressure-wash everything to make the job more fun.
    BTW, I Googled up a couple of references that gave the torque specs for this bolt as 195 and 216 foot-pounds. Does that sound close to correct?
  20. Jun 14, 2024 at 2:36 PM
    ControlCar
    Steven
    Sugar Land TX
    yeah 195 to 217
    also
    put a piece of cardboard over the inside of rad(for protection)
    this prevents any dmg to fins/etc from dropping tools, stripping a bolt and the wrench handle hits rad.....ETC
