Harley in the box?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CdnDave20, May 5, 2020.
  1. May 5, 2020 at 7:07 PM
    CdnDave20
    CdnDave20 [OP] Active Member
    Stock
    As the title says, will these 3rd gen Tacomas be able to safely carry a smaller harley in the box? tailgate down due to length. It's a 2004 Wide glide, dry weight around 650, wet probably 700ish. It's not an even load distribution so I'm worried about busting the tailgate off when we try and unload or load it.. anyone have experience with this?
    Thanks!
  2. May 6, 2020 at 4:38 AM
    advrider963
    advrider963 Member
    Jimmy
    NW of Chicago
    2019 CB TRD Off Road 4X4 Access Cab
    I have hauled my KTM 990 that weighs 460ish lbs. in the bed. I just moved it local, 30 miles and it did ok. I used a chock on a wide piece of plywood and 4 tie downs. It nerve racking to get up and down on the narrow ramps I used. I wouldn't haul it a long distance that way
  3. May 6, 2020 at 5:01 AM
    Rapidfire1
    Rapidfire1 Well-Known Member
    Shaun
    York Pa
    2016 Black TRD Sport DCSB MT
    I hauled my Yamaha Fz09 multiple times over hundreds of miles with weight on the tailgate without issue, but that thing only weighed about 500lbs wet.
  4. May 6, 2020 at 5:15 AM
    Upstate NY
    Upstate NY Well-Known Member
    Rob
    Hudson Falls
    2018 TRD Access Cab
    LT265/75 R16 Goodyear Wrangler Duratracs WeatherTech hood guard WeatherTech side window deflectors Toyota bed mat Alabama Crimson Tide hitch cover
    DO NOT put that amount of weight on the tailgate. Put long (preferably curved, wide) ramps directly on the bed edge after removing your tailgate. The length of the bike might require you to load it diagonally in the bed. If your ramps are too steep you will bottom out the bike. Seriously be darn careful and have extra eyes and hands when you are attempting this. Backing truck in towards an uphill can help reduce the ramp incline. Strap the ramps in place to prevent them from kicking out. Look up some motorcycle loading fail videos first! They may make you change your mind if your loading situation looks similar to any of the ones you see!
    YOTA 4X4 and Chew like this.
  5. May 6, 2020 at 5:34 AM
    Shellshock
    Iowa
    The tailgate will support it but if you are going very far, the ride of your truck is gonna be terrible if you have stock leafs.
    Personally I use a trailer. Much easier loading and unloading. Better drivability and ride.
    Lt. Dangle, yub, Rock Lobster and 2 others like this.
  6. May 6, 2020 at 5:54 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Get a trailer. You will screw something up trying to put that bike in the bed.
    G.
    Lt. Dangle, Chew and travis.diller like this.
  7. May 6, 2020 at 6:13 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    I am one of those people who carries WAY too much in my bed. (I probably had 2k Lb in mine a few weeks ago https://www.tacomaworld.com/threads/tacome-bed-weight.661205/#post-23183886)
    I would only do it with air springs (or similar).
    I would personally build a platform for it... without running any numbers I would do something like this. Is this more effort than using a trailer?, yes...
    ONLY tie down straps to the bed bolts. Make 100% sure you are providing restraint for fore/aft loads besides the bed front wall, you will destroy it with a hard stop.
    Warning, I did not run numbers on this, but it seems ample to me... PowerPoint engineering ahoy.Slide1.jpg
    BTW, I would install that over a rubber bed mat, and shim with plywood at the tailgate as required.
  8. May 6, 2020 at 6:14 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    came here looking for a new joke toy like Elf on a shelf.. Harley in a box :confused:o_O
  9. May 6, 2020 at 6:15 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    I hang mine off the back...truck rides like it’s not even there although the setup (bike and carrier) is around 540lbs.
    sparechange, Thunder Road and uurx like this.
  10. May 6, 2020 at 6:19 AM
    aahyut
    aahyut Well-Known Member
    Sweden, Maine
    2019 TRD OR DCSB
    My hauling motto: If it fits, it ships.
    Black64 and fmb like this.
  11. May 6, 2020 at 6:25 AM
    cgs2k2
    cgs2k2 old man
    there are a few different steel tailgate reinforcement plates that some companies sell that may help keep your tailgate in tact/reduce bending
    you may want to look into those if this is a common occurance for you
  12. May 6, 2020 at 6:26 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    If you have a ditch next to the side of a rode back the truck into it and try to drive the bike in. Much easier than ramps.
  13. May 6, 2020 at 7:04 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    first gen zx10r (widowmaker), NICE! i had a blazing pearl orange one, up until about 2015 when i upgraded to the 4th gen. havent hauled the sportbikes in the tacoma yet but, i dont see an issue. we haul 2 dirt bikes back there all the time. pic for attention, me at "the gap". Ski
    sparechange and Ronzio[QUOTED] like this.
  14. May 6, 2020 at 8:07 AM
    NavyDad
    NavyDad Well-Known Member
    1981 Suzuki GS850G weighs in at 605 pounds as it sits. Dropped tailgate, put ramp on tailgate and secured with a tie down strap. 600 pound bike with 190 pound rider rode up ramp over tailgate. Bike tied down and then drove 600 miles to new location. Unloaded bike. Hauled from Norfolk to Ohio through the Virginia and West Virginia mountains with no issues at all. Never knew the bike was back there until I looked in the mirror. Fuel mileage didn't suffer much either. suzuki.jpg
  15. May 6, 2020 at 8:13 AM
    erklep
    erklep Well-Known Member
    Erik
    San Diego, CA
    2015 Access cab, 07 Dcsb(Sold), 06 4R(Sold)
    I used to haul around some light bobbers and cafe bikes that were sub 500lbs with no problem however I did a favor and picked up a buddy's Dyna once and buckled my tailgate. It was just too heavy that the rear leafs couldn't absorb properly. Nice $600 lesson learned. Throw down a half sheet of 3/4 ply first and you should be okay. Other option, as mentioned, is to get one of the tailgate reinforcement plates. Loading will not be an issue, its the transport that will do the damage.
  16. May 6, 2020 at 8:19 AM
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    excellent taste sir. Mines a 2015
  17. May 6, 2020 at 8:45 AM
    Tacospike
    Two Trucks
    I fit my Sportster 72 in there with tailgate down
  18. May 6, 2020 at 9:44 AM
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    imagejpeg_0.jpg I've gone cross country like this, though the bike weighed in a bit less than your Harley.
  19. May 6, 2020 at 10:07 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Geez you guys worry too much. OP, get you a piece of 3/4 plywood and set the bike on it. Tie it down with 4 straps and move on with life.
    Vea likes this.
  20. May 6, 2020 at 11:33 AM
    CdnDave20
    Stock
    Thank you everyone for the great tips and tricks! I have a few things up my sleeve now! Very much appreciated. It's a good 650km trip so wanted to make sure it would be safe.
    You guys rock!
    BigWhiteTRD likes this.
