Hardwiring Dashcam
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Landonri45, Jan 3, 2023.
  1. Jan 3, 2023 at 10:27 AM
    Landonri45
    Landonri45 [OP] Active Member
    2023 Toyota Tacoma SR
    Hello I’m hardwiring a dash cam to my 2023 Tacoma SR and was wondering which fuse would be best for constant fuse slot and ACC fuse slot. Can I use the empty slots?
  2. Jan 3, 2023 at 10:40 AM
    oogielaflick
    oogielaflick Well-Known Member
    Keith
    2019 Toyota Tacoma TRD Sport 4-door; Prvious 23 year owner of 1996 Tacoma
    Quicksand with hood protector, color matching decals on tailgate latch, mudflaps, glovebox, and tailgate hitch cover.
    There is a very much easier way to do it! Get yourself a DONGLE! It plugs into the back of the rear view mirror into the power outlet. It then lets you plug the mirror power cord back in and offers another USB port to plug your dash cam, or whatever else, into it. No wires hanging down and it is super easy and cheap! I just got the link which I will post below, but i see they have raised the price a lot! Once you see it though, do a google search and you can probably get it cheaper somewhere. But it is a cool thing, so simple and it works! https://www.amazon.com/Dongar-Technologies-Adapter-12-pin-Generation/dp/B07DMW3DML
    I just learned that not all models of Tacomas have this plug in their rear view mirror! Sorry about that! But for those who do have it, this dongle is great! I mounted my dash camera on the windshield in the area where it comes with "shading". Standing outside the truck, you can't even see the camera so i really like it, and no wires hanging down! But sorry, I didn't know about SRs and other models. I really thought that would be standard by now!
    MonsterMan, PasoSteve and Chew like this.
  3. Jan 3, 2023 at 10:47 AM
    erwigg
    erwigg Well-Known Member
    Eric
    Oregon Coast
    2022 Tacoma access cab SR
    The dongle only works if he has the connection in the mirror- SR nd some SR5 don't have them. Since he has a SR he has to hard wire it in.
    Haz 15a third from the botto right siedis iempty and will give constent power while the P/outlet NO1 15aa third from the top left is switched
  4. Jan 3, 2023 at 10:48 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    any empty slot in the under dash fuse box that has 12v should work
    Landonri45[OP] likes this.
  5. Jan 3, 2023 at 10:54 AM
    erwigg
    Eric
    Oregon Coast
    yeah just enough of us cheap weirdos to trip you up like that
  6. Jan 3, 2023 at 11:04 AM
    Landonri45
    So do I use a fuse tap because right now it’s just a wire. And if so what amp do I use for both fuses?
    HondaGM[QUOTED] likes this.
  7. Jan 3, 2023 at 11:05 AM
    erwigg
    Eric
    Oregon Coast
    some of the wiretap sets have a typically works
  8. Jan 3, 2023 at 11:11 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Does the instructions say what amp fuse is needed
  9. Jan 3, 2023 at 11:16 AM
    Landonri45
    No it didn’t come with any instructions. That’s why it’s annoying
  10. Jan 3, 2023 at 11:18 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    well..i would start with a 10 amp
  11. Jan 5, 2023 at 11:30 AM
    BmTaco91
    BmTaco91 Well-Known Member
    Alberta Canada
    2021 AC TRD OR 6MT
    I just did one using a fuse adaptor and used the 5 amp one from the top left down 5 slots . Turns off with key . Anyone that turns off when your turn the ignition off should work Z dash cam shouldn’t need more then a 5 amp fuse .
