hard shimmy on the downhill when braking???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by skweezal, Mar 27, 2022.
  1. Mar 27, 2022 at 7:59 PM
    skweezal
    skweezal [OP] Well-Known Member
    Thoughts on what it might be? I have a 2019 4wd tacoma. the past 6 months I have noticed a little shimmy when the brakes were applied on the steep downhill...haven't thought much of it till 4 days ago. Went to Death Valley and did 60 miles of hard offroad (awesome!). Coming out of DV on the pavement roads and steep downhill. WHen I applied the brakes, it was a violent shimmy, even at low speeds (35mph). When we came off the pass, I tried braking hard on the flats and it was fine. We are launching into diagnostics soon but I am wondering if anything springs to mind for anyone? TIA!! (BTW, Death Valley was epic!)
  2. Mar 27, 2022 at 10:09 PM
    brtnstrns
    brtnstrns Well-Known Member
    Seattle
    2020 Voodoo Blue TRDOR DCSB
    Sounds like warped brake rotors due to overheating.
    Chew, $yoda$, 2020SilverSky and 5 others like this.
  3. Mar 27, 2022 at 10:33 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    When you are hard on the brakes the vibration is gassing of the brake material pushing the pads away from the rotor. The gas builds, then vents, build again etc, etc. I have experienced this as well. I adjusted my driving to prevent it. Upgrading to a slotted rotor would help if you plan more hard braking events like this in the future. The slots give the gas a place to vent quicker.
    AZ Pete and piratepegleg like this.
  4. Mar 28, 2022 at 2:33 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    What trim Tacoma?
    And you’re sure it wasn’t like the anti-locks kicking in?
  5. Mar 28, 2022 at 5:45 AM
    skweezal
    that was my first thought but when I brake hard on the flat it's smooth.
  6. Mar 28, 2022 at 6:07 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    My bet is pad build up on rotors, rotor rarely warp.
  7. Mar 28, 2022 at 6:12 AM
    skweezal
    would that shimmy on the downhill but not on the flats?
  8. Mar 28, 2022 at 7:45 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    I would suggest you inspect all 4 wheel brakes and look for uneven wear. I wonder if it’s the rear brakes. Good luck
  9. Mar 28, 2022 at 7:48 AM
    na8rboy
    WI
    Yes, the harder you brake the more extravated it will be.
    Chew likes this.
  10. Mar 28, 2022 at 8:38 AM
    brtnstrns
    Seattle
    Actually this just reminded me that this happened to me in a rental car in Maui coming down from Haleakalā. Was worried I totally screwed up the brakes on the descent as it was violently wobbly but then once we got back down to the flat land the brakes operated as normal. I just decided to not put any thought into it and turned the car in and went on my way so not sure what the deal was.
    Sounds like @Speedfreak may have the right idea though.
  11. Mar 28, 2022 at 8:49 AM
    NewMexiMan
    NewMexiMan Well-Known Member
    2016 SR 5 Speed
    I had the same thing happen to me recently, also in Death Valley, coming down Emigrant Pass. Interested to learn the cause.
  12. Mar 28, 2022 at 10:30 AM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I’d also look for any potential “play” in the suspension system after looking for dragging brakes.
    1. Wheel bearings
    2. Control arms
    3. Bushings
    4. Ball joints
    5. Tie rods
    6. Cracked or broken leaf spring
    7. Loose leaf spring
    8. Loose lug nuts
  13. Mar 28, 2022 at 12:08 PM
    Frankenstuff
    Frankenstuff Busy iracing
    Frankie
    16TRDORDCsb 4x4 & 2020 BMW M2 competition
    16 trd ORdcsb4x4 c4 swingout rear, cbi t3 front , arb lift,16"grabber x3 rtt, hilift,jerry cans,and sliders . 81 hilux trail donkey
    Was just wondering if you might be lifted ? Suspension drop out in the rear might be causing added driveshaft angle and vibration .
  14. Mar 28, 2022 at 1:18 PM
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    It's more than likely brake pad material transferred to the rotor. You could do a brake pad bedding sequence. Where you get it up to 50/60 then brake hard and constant down to 20mph. Repeat a few times. Then take for long ride to cool down the rotors. Sometime when we panic brake, or brake real hard , and leave our foot on the pedal, the pads transfer some material onto the rotor. I just had this with the Mrs. Accord. i was able to scuff off the transferred material, and the pulsing went away. So when braking real hard leave foot off the pedal. I put my vehicles in park when this happens to avoid the transfer.
    na8rboy likes this.
  15. Mar 28, 2022 at 1:29 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Warped rotors. Try resurfacing them and reinstall.
    Chew likes this.
  16. Mar 28, 2022 at 4:02 PM
    Sierrahunter
    Sierrahunter Well-Known Member
    2022 SR5 Double Cab Long Bed 4x4
    It's your rotors. I was constantly getting rotors resurfaced on my 2nd generation.
  17. Mar 28, 2022 at 4:35 PM
    ktmtacoguy
    ktmtacoguy Active Member
    2021 Tacoma TRD Off Road DCLB
    Ironman 3" Foam Cell suspension lift, Black Rhino 17" Stadium wheels, 285/70/17 Falken Wildpeak AT3W tires, Body Armor Hiline front bumper, Smittybilt X20 winch, Diode Dynamics front low beam/high beams/fogs.
    As noted above, it's likely warped rotors. Happens all the time. Use the engine braking when coming down steep or long hills to avoid overheating them.
    Chew likes this.
  18. Mar 28, 2022 at 4:42 PM
    Little Lion
    Little Lion Well-Known Member
    2018 Barcelonian Sport MT
    i got this problem too, even when vehicle was fully stock. happened on mountain passes in rockies both in a tacoma and land rover. maybe its from bad driving? braking in a way that overheats the things? i have manual and try to not wear transmission or brakes too hard but always happens on big road trips... so, subbed :rolleyes:
  19. Mar 28, 2022 at 5:45 PM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    I have it too, its more likely warped rotors than anything else.
  20. Mar 28, 2022 at 6:30 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Check rotors.
    Check boiling point of fluid.
    Chew likes this.
