Hard shifting in A340 after transgo kit and rebuild
Discussion in '1st Gen. Tacomas (1995-2004)' started by cjolson, Oct 21, 2021.
  1. Oct 21, 2021 at 12:55 PM
    cjolson
    cjolson [OP] Member
    San Diego, CA
    2000 PreRunner
    4wd conversion, Bilstein 5100, 3" lift, 4.30 rear E locker
    I recently dropped my A340e transmission, swapped out the output shaft from an A340f, and added a transfer case for my 4wd conversion. While I had the tranny out I also installed the transgo SK 340 kit in the valve body.
    Since installing I've noticed that the shifting has been more aggressive - going from park to drive the truck pulls forward with a lot more go and some of the shifts are a bit hard. The symptoms really only seem to be there when transmission is cold, maybe the first 5 minutes after startup. In general the transmission is noticeably more responsive, but I am concerned about those hard shifts.
    I'm wondering if anybody else has installed the transgo kit and this is normal or if I should be worried that I did something wrong with all the work that I did. One of the things that the transgo kit has you do is remove some of the check balls in the valve body, which I thought was really strange, but did anyway. If anybody else has dealt with this I'd love to get some TW insight!
  2. Oct 21, 2021 at 1:03 PM
    gearcruncher
    Canadain bumper technician
    inwood customs likes this.
  3. Oct 21, 2021 at 1:32 PM
    cjolson
    cjolson [OP] Member
    San Diego, CA
    2000 PreRunner
    Yes, it has the kick down cable going into it as opposed to an electric one. Could it be an issue with this being out of adjustment? I tried to reinstall with the same cable tension, but perhaps I messed that up?
    If I'm not mistaken I only removed one valve to install the transgo bits. I was very meticulous but I suppose it's possible I did something there. Since it seems to be doing well once it's warmed up, I would be more inclined to think that maybe it's a "sticky" valve rather than a completely stuck valve.
  4. Oct 21, 2021 at 1:38 PM
    gearcruncher
    If you go to that link above there is an adjustment for the cable in PDF format . In most cases those cables stretch over the years causing sloppy shifting and low pressures . That being said , I doubt its a cable issue .
    Without looking at the shift kit instructions , my first guess is a sticky valve . Sticky valving is common after transmission work
    You could try Lubegaurd black . That stuff works wonders for sticky valves .
    https://www.amazon.com/Lubegard-619...keywords=lubegard+black&qid=1634848624&sr=8-4
  5. Oct 21, 2021 at 2:30 PM
    cjolson
    cjolson [OP] Member
    San Diego, CA
    2000 PreRunner
    Awesome, that thread is (and has been) such a great resource!
    Thanks for the tip on the additive - I will try that and see if it helps.
  6. Oct 21, 2021 at 3:18 PM
    lm546
    lm546 Well-Known Member
    Craig
    Tucson, AZ
    2015 dcsb OR, 2002 double cab, 1985 Toyota pickup
    I will be interested to see if that works for you. I just had the same kit installed with a rebuild and had the builder install the street springs. My shifts from park to drive or reverse are aggressive as well. I have had shift kits on other vehicle and have never had anything near as aggressive as this. The builder said he never recommends shift kits beside race vehicles and heavy tow rigs, because on daily drive they are usually more aggressive than most are expecting.
    have you had the builder take it for a test drive? I have being meaning to have mine driven, but haven’t had a chance to get there.
  7. Oct 21, 2021 at 7:33 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    I would try to adjust that kick down cable and see if that helps. Also how many miles did you put on it since the install and did you reset ecm memory.
    Wulf likes this.
  8. Oct 21, 2021 at 7:51 PM
    GEN1_MK2
    GEN1_MK2 Member
    Roger
    San Diego, CA
    2000 Toyota Tacoma PreRunner to 4x4 Conversion
    4x4 Conversion, Tundra spec trans with red clutches and TransGo shift kit, FJ J-shift, Northwest Fab Eco Crawler with Trident triple shift, AISIN manual locking hubs, King Extended Coilovers with 650# springs in the front with King 12x2.5 in the rear with resi's & adjusters mounted on custom underside bed cage, JBA UCA, AllPro Expeditions, DuroBumps, Ubolt Flip, Fabzone Sliders, Yukon 4.56 Front & Back, Baja Design Lights, Prinsu Roof Rack, CBI Overland Bars, Smittybilt Defender Rack, Midland GMRS, K&N, Energy Suspension Everything, Custom Magnaflow Exhaust, AllPro Shackles & Spindles Gussets, Antirock rear universal swaybar, Marlin Crawler Brake Lines and Powerstop Rotors, Husky Tool Box, ProComp Rock Lights, SwitchPro 9100, BedSlide S, Wheels 15x10 Alcoa, 33x12.5 BFG K02's.... That's it.
    I have the transgo kit installed into my A340F. There a a couple of settings you can choose when you drill out the hole in the valve body gasket. "hot rod" & "truck". the hotrod setting will cause the trans to shift really hard. Could it be possible you used the hodrod setting? Mine is set to truck and the shifts aren't that bad.
    You can also over tension the kickdown cable at the throttlebody and it will cause the transmission to shift hard with the transgo kit installed. it's best to set it with little to no slack. if you over adjust it will overpressure your shifts.
  9. Oct 22, 2021 at 2:10 PM
    cjolson
    cjolson [OP] Member
    San Diego, CA
    2000 PreRunner
    I did all the work myself so I didn't have a transmission person to drive and tell me if what I'm feeling is normal. I suppose it's good to hear that you are having similar results from your install. As others mentioned I will check the cable this weekend and then try some of that lubegard additive.
  10. Oct 22, 2021 at 2:51 PM
    cjolson
    cjolson [OP] Member
    San Diego, CA
    2000 PreRunner
    I've probably put about 200 miles on it so far. I disconnected the battery completely before I dropped the transmission - does this reset the ecm memory? Sorry for my ignorance if there's a proper way to reset the ecm.
  11. Oct 22, 2021 at 3:28 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The TW urban legend says that to reset the ECM, disconnect the battery for a minimum of 30 minutes. This is likely based on facts, the FSM perhaps. :notsure:
    You should be good.
    cjolson[OP] likes this.
  12. Jan 3, 2023 at 6:52 AM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Did you figure out what your issue was? #oldthreadbump
    inwood customs and Digiratus like this.
