Harbor Freight Tool
Discussion in '1st Gen. Tacomas (1995-2004)' started by CrippledOldMan, Mar 5, 2019.
  1. Mar 5, 2019 at 1:31 PM
    CrippledOldMan
    CrippledOldMan [OP] Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Has anyone used this ball joint removal tool with success. I purchased it on sale with coupon for $59.00 and some change.
    Ball Joint Service Kit for 2WD and 4WD Vehicles
    Maddox- Item#63279
  2. Mar 5, 2019 at 1:39 PM
    WanderingTaco
    WanderingTaco TTC #136
    Erik
    Conroe, TX
    2011 Prerunner
    My friend bought one to replace the ball joints on their f-150, the first time we used it, it bent and wouldn't remove the ball joints.
  3. Mar 5, 2019 at 1:42 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I've heard relatively good things about them (relative to their price). Most of the harbor freight stuff I consider "1 time use", and if it lasts more than that, it's a bonus.
    If it doesn't work, you can always rent a much higher quality tool from an AutoZone/O-Reily's for free.
    Area51Runner likes this.
  4. Mar 5, 2019 at 2:27 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Great for pressing out bushings! Used a similar one off Amazon to do steering rack bushings.
  5. Mar 5, 2019 at 2:29 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I would've just rented a free one from an auto parts store. I've heard HF cast iron stuff can be shitty, and this is coming from a HF lover
    This is an advanced auto one doing work.
    https://www.youtube.com/watch?v=x_JhoRVU1-w
  6. Mar 5, 2019 at 2:53 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    I saw that but following @Timmah! video I got OTC that was on sale on Amazon. Made the easiest ball joint work ever.
  7. Mar 5, 2019 at 2:54 PM
    flenniken7
    flenniken7 Wishin' I was Fishin'
    OKC
    2000 4x4 tacoma 1996 Z71 DD 248K, 2012 tahoe
    5100's 285' to come 4" lift 33's on hoe
    should work fine, buy it and give it a try. You have 90 days to return.
  8. Mar 5, 2019 at 3:59 PM
    Mulepadre
    Mulepadre Mulepadre
    Central Arkansas
    2003 Std Cab 2.7L 4x4 & 2024 Off Road
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs on 2003 King 2.5 shocks front and rear on Off Road
    Agreed
  9. Mar 5, 2019 at 6:08 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I've replaced the LBJs on both my 95 trucks within the last month. I used plain old separator fork and the following method:
    remove tire/wheel
    separate the outer tie rod from LBJ
    roll floor jack under the hub and apply lift with a wood block between the jack and the hub; this compresses the coil spring a bit
    heat the spindle socket around the LBJ with a torch; you may get a little flame/burnt rubber from the joint but no need to go crazy with the heat
    two or three medium force wacks with the separator and the down force from the coil spring will pop out the ball joint
    Not seen any problems with this method. Of course this destroys the old joint, so it is only for use when replacing them.
  10. Mar 6, 2019 at 9:46 AM
    chiefO
    chiefO Well-Known Member
    Fresno, CA
    2005 Tacoma 4x4 Double Cab SB
    ^^^^^ This. Just rent it for free from O'Rileys or something. You have to put a deposit down and then you can just return it after you use it. I'm sure that it will be better quality than Harbor Freight.
