harbor freight lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anotherreject, Mar 30, 2012.
  1. Mar 30, 2012 at 8:53 AM
    anotherreject
    anotherreject [OP] Well-Known Member
    does anybody have pictures of the harbor frieght off road lights lit up at night. im just seeing if they are any brighter then my cheapo walmart off road lights
  2. Jun 18, 2013 at 9:38 AM
    calebdnehus
    calebdnehus Well-Known Member
    Caleb
    Arkansas
    '98 Prerunner V6--2004 Tacoma facelift
    K&N cold air intake FPIK, FlowMaster 40 series muffler, Euro Diamond clear headlights, 2003 tacoma tailights, bixenon HID headlights, 4 inch lift, pioneer headunit w/kicker door speakers(amped w/Rockford four channel), 2004 facelift, led dash light mod, painted needles, black auto shifter, leather steering wheel, ultra gauge. Plenty to come... Still
    I have some harbor fright lights. Can't figure out how to aim them though
  3. Jun 18, 2013 at 5:03 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    Which ones are you talking about?
    I had the KC Daylighter style for my old Xtracab on my "roll bar". I never got them wired up (chased a bad ground issue for awhile until I sold the truck) but the quality was awful. The connections were all plastic and cracked before I even got them on the truck. The chrome finish rusted out the second water hit them.
    If you're talking about a different set of lights, I can't comment, but my advice would be to run away.
  4. Jun 18, 2013 at 7:06 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Harbor Freight makes Walmart look like top quality. :poking:
  5. Jun 19, 2013 at 9:22 AM
    calebdnehus
    Caleb
    Arkansas
    They're the US general off road lights. They are in a chrom case but that'll be painted before long to avoid rust. The lights work good with 55 watt hogan bulb for now but they'll be HID before long. I just got a set of cheap lights to turn HID. When they get messed up I'll spend actually money on good ones when I have money. Haha
  6. Jun 19, 2013 at 10:58 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Have you looked at aircraft landing lights? Napa and other parts places usually sell them, the ones I used were 4in and 6in at 100w.. You need to buy the black rubber housing to fit the lamps but they were usually way less than Hella/PIAA kits.. plus when they burn out its a $20 bulb at the parts shop..
  7. Jun 19, 2013 at 12:01 PM
    calebdnehus
    Caleb
    Arkansas
    How much did they run you?
  8. Jun 19, 2013 at 1:28 PM
    vicali
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Well it was a few years ago, and $CAD, but the 4.5in ones were around $60 and the 6in were under $100..
    Here is a pic from back then;
  9. Jun 19, 2013 at 5:16 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    You didn't have issues with the plastic nuts/screw that hold the wires into the housings snap into many pieces?
    Mine were broken nearly out of the package. I ended up hitting everything with silicon in a sad attempt to solve the problem. It didn't work.
  10. Jun 19, 2013 at 6:49 PM
    calebdnehus
    Caleb
    Arkansas
    No, all of mine are in tact as of right now. I just plasti dipped the whole casing to avoid rust and water intrusion. I will hopefully order my HID kits tonight and replace the bulbs and wires
  11. Jun 19, 2013 at 8:08 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    aside from impact sockets, harbor freight stuff is prone to fail the second you need it. I do admit to having a decent floor jack from them, and some end wrenches that are still alive, but I've had to throw away numerous 12v air compressors, ratchets, standard-wall sockets, etc.
    all of these failures occurred in dire situations and often resulted in bloody knuckles
  12. Jun 19, 2013 at 11:05 PM
    calebdnehus
    Caleb
    Arkansas
    I didn't know they sold poor quality. I thought they had decent things there, that's why I picked up the lights. Plus they were a cheap light that I could turn into HID easy. I just painted my casing today to seal and prevent rust. I figure they should last a while if I can get the beam to point where I freaking need them too
