Hankook DynaPro ATM RF10 P245/75R16; I need advice on which one to purchase
Discussion in 'Wheels & Tires' started by pos3idon, May 11, 2011.
  1. May 11, 2011 at 3:48 PM
    pos3idon
    pos3idon [OP] Active Member
    New York
    2011 Tacoma 4x4
    12 Volt outlet in bed, Leer Topper, UltraGauge, second battery
    I am preparing to purchase my first new set of tires for my 2011 Toyota Tacoma Access Cab, after much research I believe that I am going to purchase the Hankook DynaPro ATM RF10 P245/75R16's because of the off-road capability and the (hopefully) good highway MPGs (does anyone have these on their truck? Did you lose MPG's?)
    Anyways, when I went to research them I realized that there are many different sub models ( P265/75R16 114T, 116s ect...) Now I am thoroughly confused, can anyone help me figure out which ones to order? I am running a completely stock truck (except for the leer topper on the back).
  2. May 11, 2011 at 5:07 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    My 3 trucks (2001, 2005, 2010: 4WD Off Road TRDs) all came with 265/70-16 tires (BFG Rugged Trails).
    When I got my DynaPros 3 months ago, I got them one inch taller: 265/75-16 and that gave me 1/2" more ground clearance as well as made my too fast speedometer read correctly!
    I am extremely happy with the DynaPro ATm's for highway, snow, mud and desert use... so far!
  3. May 11, 2011 at 6:09 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I got around 18.5mpg with my 245/75R16 Dunlop AT20s. This is the first full tank in my 265/75R16 p-rated Dynapros where I filled up sequentially at the exact same pump, and I got 17.9mpg. I expected to lose about 1 mpg, and I probably lost around that, maybe a bit more, as the 18.5 avg was through winter when mileage is worse. I may still bump up from 36 to 38 psi and see what that does for my mileage.
    Truck looks way better, no way would I go back to the 245s.
  4. May 11, 2011 at 7:48 PM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    The three digit numbers you are referring to are indicative of the load range. Look here at the size chart and it will tell you the load range in pounds in relationship to that three digit number.
    http://www.hankooktireusa.com/Product/product.aspx?pageNum=1&subNum=1&ChildNum=4&FnCode=044
    I have P series 265/70/17 on mine, so i could only have load range 113, but other sizes are available with multiple load ranges.
    I lost less than 1 mpg when going to the bigger size and the more aggressive tread from my 265/65/17 bridgestone dueler ht's. But i also got 2" wider wheels with real stainless streetlock bolts, so I'd bet my mpg loss is mostly from the weight of the wheels.
    You won't be disappointed with the ATM's. Especially for the price. Get them now before the rest of the world discovers them and they go up $300 for a set.
  5. May 11, 2011 at 9:15 PM
    ontarioyota
    ontarioyota Well-Known Member
    @scott777taco INSTAGRAM
    SW Ontario, Canada
    2001 Reg Cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs, summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    they sure are not cheap up here in Canada...and hard to get!
  6. May 22, 2011 at 8:35 AM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    bump for the same question...
    I'm hoping dropping to the 245/75 gets me a bit better gas mileage than the 265/65. They're essentially the same diameter.
    Anyone?
  7. May 22, 2011 at 3:17 PM
    Polymerhead
    Missouri
    It should give you a little bit better actual mileage, because it should be lighter and the 245/75 has a slightly smaller footprint. Will it be enough to notice? No idea.
  8. May 12, 2014 at 12:39 PM
    Nsjones
    Nsjones New Member
    13 4cyl prerunner
    Camper shell w/ Yakima racks
    What about if you have 4 banger?
    Will bumping up to 265 put too much strain on the engine or no??
