Hankook Dyna Pro ATM 265/75/16, Tire Pressure??
Discussion in 'Wheels & Tires' started by rp2000r, Sep 16, 2011.
  1. Sep 16, 2011 at 6:53 AM
    rp2000r
    rp2000r [OP] Well-Known Member
    2011 Tacoma DC SB TRD Sport
    What are you guys running for mostly highway driving?
    And do I need to have the TPMS set if I change the pressure from say 30-35lbs?
    Discount set them at 29f, 29R
    Thanks, Ryan
  2. Sep 16, 2011 at 8:19 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Hy Ryan, I am running mine at 38 psi front and back.
    They are a 44 psi max. tire and the Rugged Trails that came with the truck were only a 35 psi max. tire (with a recommended run pressure of 29 front, 32 rear).
    The Dynapros are a superior tire to the BFGs, and with a stronger make/ heavier rating need a bit more air than the BFGs did.
    They will feel 'squishy' at 29-32 psi... 38-42 they feel good. You can do the chalk test to see the ideal pressure, if you want. But, at 38 psi, mine are driving and wearing great.
  3. Sep 16, 2011 at 6:01 PM
    rp2000r
    Thanks for the info, If I air them up will the TPMS sensor light come on and need to be reset?
    Thanks!
  4. Sep 16, 2011 at 6:25 PM
    David K
    Yes... it is easy... in your owners manuel is the instructions.
  5. Sep 16, 2011 at 8:04 PM
    rp2000r
    Gotcha, I guess I should probably read it sometime! :D
  6. Sep 17, 2011 at 6:39 AM
    David K
    10-4 that!! ;)
  7. Sep 18, 2011 at 6:17 AM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    I run my P-series dynapros at 38 PSI front, 35-36 PSI back. DCSB 4x4.
  8. Sep 18, 2011 at 9:42 AM
    David K
    Just a curiosity question: Why 2-3 psi less in back? With Rugged Trails, Toyota recommends 3 psi more in back... Just for simplicity I run my backs the same as the fronts (38 psi). Thanks.
  9. Sep 18, 2011 at 10:07 AM
    Polymerhead
    Missouri
    I base it off of sidewall flex. I like a nice flat patch of contact with just a little flex but not much. In my truck, the flex (bulge) in the front is noticeably more than in the back at any given pressure. Cranking up the PSI in the front a bit evens it out. I figure I'll get more even wear if contact patches and sidewall characteristics are as close as possible.
  10. Sep 18, 2011 at 10:11 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Interesting.:cool: I run mine at 32 PSI front and back. Maybe i'll change it up. BTW, do you have any problems w/ the lugs chunking? Might just be the desert wheeling.
  11. Sep 18, 2011 at 10:20 AM
    rp2000r
    Mine are P Series and I set to 38F, 38R, Will see how it rides...
    DCSB 4x4
  12. Sep 18, 2011 at 10:29 AM
    David K
    I have 10,000 miles on my Dynapros, and they still look pretty new... no failures, flats or 'chunking'.
    Maybe because your pressure is too low for those tires?
    The Rugged Trails are 35 psi max tires and I ran them at 32 (the rear recommended amount by Toyota). But, the Dynapros are 44 psi max tires.
  13. Sep 18, 2011 at 2:08 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Killed this little guy trying to pump 38psi. Lol.
    Sent frum mobul fone soe don't freek out about my speling and grahmar. ;)
  14. Sep 18, 2011 at 2:22 PM
    Polymerhead
    Missouri
    They came out of the wheel shop set to 30 all around. Mine are p-series, and they showed way too much sidewall flex. I would expect very short lifespan if I had left them there. They looked half flat.
    Remember, these ARE p-series but they're also more sturdy than a standard car tire. While most p-series tires have a max PSI of around 36. P-series dynapros have a max PSI of 44 if I remember correctly.
    I have no experience with the LT-series tires.
    ETA: No chunking but only about 6K miles on the tires and I run 95% highway.
  15. Sep 18, 2011 at 4:59 PM
    David K
    Look just a couple posts up... 44 psi is the max... and for my DC 4WD, 38 PSI works very well.
  16. Sep 22, 2011 at 4:51 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Been running 38f and 35r all week. Truck feels great. Reps when I get on my PC.
  17. Aug 19, 2015 at 3:18 PM
    gimmeajo
    gimmeajo i'm here for the food
    Zander
    New Orleans via New England
    '13 DCSB 4WD TRD OR
    OME 883, N140, N182, 265/75/16 Hankook ATMs, Weathertechs, chop front flaps, diff breather, killed seatbelt dinger
    Thanks to David K's suggestion, I've been running 38psi on a 4 and it rides great. The damn dealer always airs them down this time to 35front, 37 rear) and the original shop had them over 44!
  18. Aug 19, 2015 at 3:39 PM
    David K
    Do check your air gauge, it may be off?
    The factory pressure is 29 front and 32 rear on the Rugged Trail TAs the truck comes with. Surprised the dealer invented his own pressures.
    Ha! 38 psi post? That was way back in 2011!
    After that post, and I shared it here, I did the 'chalk test' and adjusted the pressure down to 35 psi all around. I now am running Dynapros for a second time, and that is where they are set, again. They only have 4,000 miles on them, so I will be watching them closely. Please do a chalk test on your Tacoma to make sure! Here is that thread: https://www.tacomaworld.com/threads/chalk-test-dynapro-atm-at-16-000-miles.226635/
  19. Aug 19, 2015 at 3:41 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    35psi f/r for me
  20. Aug 19, 2015 at 3:52 PM
    asus611
    asus611 Well-Known Member
    CA
    03 Double Cab Prerunner
    38 psi all around for me, 1st gen double cab
