Hanging RPMs while coasting in Neutral/clutch pushed in.
Discussion in '1st Gen. Tacomas (1995-2004)' started by jspansel, Sep 18, 2014.
  1. Sep 18, 2014 at 8:19 AM
    jspansel
    jspansel [OP] Just duct tape it
    Jay
    Central OR
    01 V6 Xtra Cab Tacoma, 5 Speed, 4x4, Lifted
    5100s front at 2.5" with Moog replacement springs, 5100s in rear with 2" Wheeler's AAL
    This had happened off and on last year but seemed to go away until now. While driving, If I push the clutch in or put it in neutral, the RPMS always hang around 2k. It stays there until I come almost to a stop and then it will drop down to normal idle RPM.
    Even if I am say in 5th gear going a little slower so im sitting at say 1.5k RPM, if I put the clutch in, the RPM raises up to 2k. Seems to like 2k no matter what speed I go unless I am under like 5mph or something. Then it will drop down.
    Kind of annoying and probably not the best for gas mileage although I have not seen much of an impact yet. I just dont like hearing my engine at 2k while I am coasting to a stop.
    What could be causing this? IAC? Something with the clutch? It shifts and drives fine otherwise.
  2. Sep 18, 2014 at 8:30 AM
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    I noticed mine does that too.
  3. Sep 18, 2014 at 8:44 AM
    jspansel
    Jay
    Central OR
    I cleaned the throttle body and MAF last year... Maybe i need to try that again. I never cleaned the IAC valve, so i guess I should get a gasket and do that while I'm at it.
    Not sure what else could cause it. Just weird that it only hangs while moving. If I am stopped or moving slow, it does not hang at all.
  4. Sep 18, 2014 at 9:00 AM
    bawilson21
    bawilson21 Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    I've noticed this in my truck aswell (V6). Sometimes I'll turn the engine off while coasting, but if i start it again while still moving either by bump or by key, it will still idle high while in neutral MOST of the times. A few times it has gone down back to about 700 rpms. I think it has something to do with keeping the engine up to speed incase you shift up/down. Kinda like how when you're driving and you let your foot off the gas, and then push the clutch, it revs up a bit.
    However, this very well could be a moot point depending on what you're trying to achieve. The Tacoma's have something called Deceleration Fuel Cut Off (DFCO). Essentially, while you are coasting IN GEAR, fuel stops being injected into the engine, while the momentum of the car will keep the engine turning. This will apply some additional resistance/braking power. Good when coming to a stop or maintaining speed going downhill. You can read more about DFCO at the link below.
    http://ecomodder.com/forum/showthread.php/please-explain-dfco-deceleration-fuel-cut-off-14362.html
  5. Sep 18, 2014 at 9:15 AM
    jspansel
    Jay
    Central OR
    Interesting...
    Just seems weird that It seemed to do it and not do it at times... At least as far as I recall. :confused:
    Doubt its hurting anything... My MPG still seems good.. (20mpg average).
    Still probably go through and give all the goodies a cleaning. Could use it anyways.
  6. Sep 18, 2014 at 12:03 PM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    DFCO would have no effect if in neutral or the clutch depressed since the transmission would be disconnected from the engine.
    If the RPM's remain high, it could be the throttle position sensor (TPS).
  7. Sep 18, 2014 at 12:32 PM
    jspansel
    Jay
    Central OR
    Is that something I can clean? Or test and replace? Why only while moving?
  8. Sep 18, 2014 at 1:22 PM
    quetzal
    quetzal Well-Known Member
    Mario
    Long Beach, CA
    '02 XtraCab SR5 TRD 4x4 5spd
    All-Pro UCAs, King 2.5 C/Os, All-Pro Expo Leafs, Bilstein 10" Shocks
    Its happens to me (v6, manual) right after a cold start. Appears that once the engine reaches normal driving conditions the rps come down to where they're supposed to be.
  9. Sep 18, 2014 at 2:39 PM
    jspansel
    Jay
    Central OR
    Mine does not come down after warming up. I drive about 20 miles to work each way and its just the same when I get there.
  10. Sep 18, 2014 at 2:47 PM
    bawilson21
    Bryan
    WA
    What you are describing is normal for just about every car and helps the engine reach operating temp faster for better emissions. This is not what the OP is describing.
  11. Sep 18, 2014 at 2:52 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Nothing to clean on the TPS other than the contacts maybe but you should test it with a volt meter to see if it's performing within specs.
  12. Sep 19, 2014 at 8:51 AM
    jspansel
    Jay
    Central OR
    Strange... Did not do it at all on my way home from work yesterday. But I stopped at the store before home and when I went home from there, it did it the whole time (couple miles). I was in the store maybe 5 minutes.
    I rode my motorcycle this morning.
  13. Sep 20, 2014 at 5:58 PM
    pilatus
    pilatus Member
    kurt
    valdez, ak
    2002 sr5
    i have the same problem. i cleaned the iac valve ad maf sensor, didn't change a thing. brought it to the shop and they said they could not fix it because its something with the computer because all the other sensors are operating normally.
  14. Sep 22, 2014 at 3:21 PM
    jspansel
    Jay
    Central OR
    Thanks for the reply... This is very strange. :confused: Would be cool to swap the ECU with another truck and see if it persists or not...
  15. Sep 22, 2014 at 3:34 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Mine did this when I had a bad TPS.
  16. Sep 22, 2014 at 6:02 PM
    r45d
    r45d Well-Known Member
    Georgia
    01 DC 4WD
    I had a corolla 5 speed that did this, try taping the accelerator to jump rpms just a fuzz while coasting. In my Corolla the rpm would drop to normal idle after the bump or if I coasted for longer than something like 30 seconds. Ymmv
    Edit. 04 Corolla. No idea if higher rpm is normal
  17. Sep 22, 2014 at 7:00 PM
    Madjik_Man
    Colorado Front Range
    This.
    Same symptoms for my truck years ago. High revs when in neutral (idling and coasting) and when the clutch would be pushed in.
    Replaced the TPS and fixed everything.
  18. Oct 2, 2014 at 2:23 PM
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    Mine does this random;y and will drop down to about 800 from 1500 when I rev it. Maybe TPS you think?
  19. Oct 22, 2014 at 7:30 AM
    jspansel
    Jay
    Central OR
    Finally threw a cel... p0120 throttle position
  20. Oct 22, 2014 at 8:45 AM
    nealkas
    nealkas Well-Known Member
    nealkas
    Pee-Ay
    08 Superwhite DCSB 4x4, stock.
    Funny when you are sorta relieved to see the trouble light.
    "At least now I know WTH is it." :)
